Faema Due one group continously running and buttons not responding
  • ozscott
    Cheers Mal.
    You bet 260...perhaps get a fabrications place to make
    Us up some stainless ones....
    Originally posted by ozscott View Post
    Ok so yep just the card...swapped the card from the left group to the right the one i use the most and all good on that group now. Its just a case of unplugging and then peeling off the card...see attached. New one is about $75 which is sweet...gotta love being able to get parts.
    Good one mate...
  • 260zman
    Awesome! Great when it's a cheap (ish) fix too. Yeah, I've got a few faema and its nice being able to get parts. Be better if there were some new plastic panels available for the dues aye.
  • ozscott
  • ozscott
    Thanks mate. Will do. Cheers
  • 260zman
    Hi. I'd first try disconnecting the plug on the volumetric button panel, then re switch back on and see if it still does the issue. if it does the issue will be in the main electric panel, and if not, you'll have a dodgy button.
  • Faema Due one group continously running and buttons not responding
    Hi all. Before i open her up disconnect the loom to the pcb card and spray some Corrosion X on the little terminals are there any other tips..im concerned that the card itself might be knackered..
