Every now and then after my Futurmat turns on (it is on a 15 amp timer) and it has reached operating temperature (about 30 minutes) I find that it will not immmediately froth milk. This is the case from both steaming arms. The pressure gauge shows the usual optimal level but I only get a few seconds of half-hearted steam. Then nothing....
The pressure in the boiler drops right down and the heating element cuts in. The heater stays on for a few minutes and the pressure gauge shows that boiler pressure is building up again. When the heater turns off, there is plenty of steam.....but it wasnt available there a few minutes before. This head of steam will be abundant anytime I use it while the machine is still turned on.....but it may or not be there next time it turns on....
Has anyone else had this problem?
Any ideas what I can do to get around this?
