Help! No steam!! For a few minutes, anyway...
  • #16
    Re: Help! No steam!! For a few minutes, anyway...
    I call it a "false pressure", and it happens when the ANTI VACUUM valve is stuck SHUT. ie it did not open when you turned off the machine and it cooled down, and therefore it did not allow atmospheric pressure to equalise into the boiler.
    When you turn the machine back on it goes into a false pressure situation exacty as you have found, then rights itself after you bleed off a steam valve.
    Anti vacuum valves are supposed to open and shut every time the machine is swiched on and off, to stop false pressure. But they stick shut eventually due to a build up of scale from the passage of steam.
    You get around this in the following way: when you turn off the machine you open a steam tap and let all the steam bleed off...leave the valve open. When the steam is exhausted, atmospheric pressure equalises into the boiler.
    When you switch on again, make sure the steam valve is still open. Leave it open until the machine has built up enough steam for it to start leaking out the steam pipe. When you see it leaking, close the tap. The machine will then very quickly reach operating pressure, and there will be NO false pressure situation.
    If you do the above all the time, it doesnt matter if the anti vacuum valve is stuck shut.
    To stop the anti vacuum valve from sticking shut you can occasionally just tap the top of the valve with something (screw driver handle) while the machine is on, to make sure its not stuck. The steam pressure will just bounce it straight back up and reseat it.
    A stuck valve is not a failed valve...its just struck. Tap it occasionally and you will stop it sticking. If it is stuck, tapping will unstick it and make it reseat itself.
    Anti Vacuum valves eventually fail in that the passage of steam will create a "track" through the valve, or the valve will wear in some way, or a seal will fail ( depends on the type of valve).  In this case the valve wont reseat itself properly and will leak steam all the time. Only then will I consider replacing the valve.
    Otherwise, you just make the spare parts man very well off indeed from selling anti vacuum valves to people that didnt need to buy them...they just needed to tap them!
    By the way, remember these items are directly concerned with steam delivery so if you are going to tamper with or "tap" these valves, please take care not to burn yourselves.
    Apologies for the lengthy reply (but how else would you describe and explain the above?????).
    • #17
      Curmudgeon that dosent sound quite right if your valve was stuck shut dosent that mean you would get a collapsed boiler from the vacum created when you turn the machine off??
      • #18
        Sorry Segrave, but JavaB is spreading factoids that arent strictly correct. These are pressure vessels that can withstand both positive and negative pressure. The negative pressure that results from a sealed boiler is less than 1 bar implosive pressure and should be well below what a boiler can withstand.
        What Curmudgeon describes is common on older machines. The anti-vacuum valves can get stuck closed. I suspect it is the rubber in the o-ring seal softening and deforming until it becomes sticky enough to, well, stick.
        This is the case on my Pav and I had it on my Bezzera. A new o-ring can fix it, or you can do what was suggested and what Im currently doing on the Pav, and that is tap the anti-vacuum valve open just before turning the machine on.
        The false pressure effect will cause a brief spurt of steam followed by nothing until the boiler heats up enough to generate a real pressure. This can take some minutes, after which the machine will run normally.
        The air in the boiler phenomenon is completely different and will not result in a drop of pressure other than what is normally observed when opening a steam valve. What it will do is blow large bubbles in your milk (untill all the air is removed).
        Im still puzzled as to what causes this false pressure. But this is whats happening.
        On my machine, the anti-vacuum valve is on top of the sight glass.
        Mark.
        • #19
          Mark.
          Mark,
          Whilst I agree that it is unlikely the boiler will collapse or implode, vacuum brake valves are stated to prevent this happening.... for example the following quote from Kadant Johnson who design these valves for various boilers:
          Quote
          Kadant Johnson Vacuum Breakers provide a simple, dependable
          way to relieve any unwanted vacuum condition that may
          develop in a closed vessel or pipeline. They can be used to
          prevent contamination from back flowing in fluid handling
          systems and to protect equipment against collapse or implosion.
          Unquote
          To my naive way of thinking a vacuum breaker is there to prevent a vacuum..... so for what other reason would you want to prevent a vacuum??? :-/ :-/
          EDIT:
          Just a thought.... painful as it might be....
          Assuming we allow 1 Bar vacuum to be established in the boiler..... what effect would that have on the pressurestat and the pressure gauge etc.... devices which are designed for positive pressure....can these be forced to travel beyond their design range... maybe the vacuum on the diaphragm of the pressurestat is what causes the false pressure initially.... i.e. it switches on a 1 Bar increase... above the previous -1Bar.
          Even the steam valve seals would be pulled hard into their seats by the vacuum.
          • #20
            Dont even think that the vacuum in one of these vessels would approach -1bar. -1bar at sea level equals total vacuum, and having been heavily involved in vacuum moulding processes in my working life I can assure you that the machinery involved in getting to near -1bar is quite impressive.
            Having stated the above I can also assure you that a negative pressure differential of as little as 2 or 3 psi, in the wrong circumstances, can have a devastating effect.
            • #21
              Good discussion here chaps.
              Note the small vacuum that occurs when the anti vacuum valve is stuck and the machine is off and the steam valves havent been opened, is the most common cause of rubbish being sucked back into the boiler through the steam pipes.
              And this is why equipment traders such as ourselves always recommend that when a machine is switched off, a steam valve should be opened and left open atleast until all the steam is gone.
              This is also why we advise all purchasers never to soak steam pipes.  The vacuum discussed above sucks back
              a) the garbage you are trying to soften by soaking (that shouldnt have been there in the first place) and
              b) the garbage you are soaking with (detergents, chemicals etc).
              And I can confirm, the vacuum created never causes an implosion in these boilers....and, false pressure is a very common occurence because many still dont know they should be opening the steam pipes when switching off. Nothing to worry about, just manage the equipment properly.
              Regardz,
              FC.
              • #22
                How about to prevent the false starts that this topic is about. Also to prevent suck back of nasties into the boiler as FC added.
                If there is false pressure in the boiler, the boiler wont heat up to the operating pressure, but will otherwise look operational. As soon as someone tries to froth some milk or make a shot youll get.... Not good for a commercial environment, and also not good for home machiens on timers...
                • #23
                  Regardz,
                  FC.
                  Thanks FC.... the penny has dropped!! :
                  The instructor I had was very insistent (almost overly so) that we ALWAYS open the steam valves to prevent damage to the machine at shutdown..... so Id assumed that the damage was physical damage caused by the vacuum :-[..... but sucking back rubbish into the boiler was obviously the reason!!!
                  The false pressure would cause embarrassment (might damage your reputation).... but I couldnt see it damaging the machine.
                  He was also very insistent on never soaking the wands by the way....
                  Thanks again.
                  • #24
                    A negative pressure as little as -1psi (very easily created) will support a column of water just over 650mm high, so as FC has said it will suck quite a bit of junk back into your boiler.
                    • #25
                      I think I have the gist of the above accumulated wisdom...but just to be sure:-
                      Referring back to FCs comment....
                      "Note the small vacuum that occurs when the anti vacuum valve is stuck and the machine is off and the steam valves havent been opened, is the most common cause of rubbish being sucked back into the boiler through the steam pipes."
                      am I right in thinking that if an anti-vacuum valve IS stuck...that the only way that rubbish can actually be sucked into the boiler is if proper protocol has not been performed, leaving rubbish (milk solids) caked in the steam wand by virtue of it not being flushed out straight after being used?
                      These solids then get sucked into the boiler when the negative pressure (vacuum) occurs when the steam tap is opened in a tank that has residual air (but not much developed steam) yet...
                      Or to put it another way....does this mean that if the opening of steam taps did not occur prior to shutdown and prior to startup...that the boiler cant become contaminated if a healthy shot of steam was released after the steaming of the last milk?
                      • #26
                        Paolo,
                        Firstly Ill repeat what I was told to do at the course (and have been doing religiously)..... and the reasons for this was explained by FC above...
                        When texturing milk, withdraw the wand as you turn off the steam so that it is just below the surface as the steam is turned off.... if deep in the jug (at 60C) the steam in the wand will condense sucking in some milk.
                        Wipe the wand down immediately to remove the milk residue (with a wet wipe kept for just this purpose.... not wiping the bench etc)....
                        Give a shot of steam (into the drip tray) to blast out any milk which might have happened to get sucked in.
                        When shutting the machine down- open at least one steam wand.... and leave it open until all steam is exhausted...
                        When starting up, ensure at least one wand is open until a strong jet of steam is emitted and then close the wand (a fully operational vacuum break might make this unnecessary..... but thats what I was told to do)
                        NEVER place a jug with any cleaning material under the wand to "soak off" baked on milk.... (and Ive seen cafes do that).... the steam in the wand will condense and the cleaning material will be sucked up into the wand.... and if there is a vacuum in the boiler..... its only a short route into the boiler and the water will be contaminated with the cleaning agent and the crap inside the wand which you were removing.... (that is the "damage" to the machine which I had interpreted as physical damage to the boiler :-[ :-[)
                        So yep, bad technique.... generally from people not correctly cleaning the wand after each milk texturing.... allowing it to get into such a state that drastic action is needed..... and soaking it when the machine is switched off (and cooling down) seems to be the answer...... BUT IT ISNT!!!!!
                        • #27
                          Hi Paolo,
                          Your problem really sounds like a stuck anti-vacuum valve as per Curmudgeons suggestion.
                          As for the vacuum sucking back junk into the boiler. Well that would be hard to completely mitigate, because even though you may have a cleaning technique that sounds good, there is a vacuum behind the steam and hot water valves that will try to bring any residual into the boiler. Maybe a CSers fastidious routine will be enough to prevent this. But it would be easier to fix the anti-vacuum valve and then the problem is solved and the machine will be operating normally again.
                          Mark.
