Greetings solvers of all my dilemmas
Have been given an old 2 group Z11 sans pump
Everything else seems to work fine at mains pressure so wouldn't mind attaching a pump to see what happens
The motor is a working ulka 1/4 HP (see attached pic) - clamp on pump attachment - my manual says it should be a flange connection and different motor so I guess it's been replaced at some stage
Question is where might I purchase the right pump for this machine given the part referred to in the manual schematic isn't the one I'm after?
Also - It is a 20 amp machine but heated up happily on a 15 amp power point - Any potential problem other than slower heat up?
