Hey guys,
I have myself a used but clean Rancilio S20 2 Group machine. One side is fine, makes a really nice coffee without any dramas.
The other side however, leaks hot water from between the group head and the handle.
I'm assuming its just the group seals that would do that? The seals looks good and I've cleaned it up. One thing I do notice is if I use my single shot handle, regardless of which side I use, water leaks out also. Is it possible the actual handle can be damaged? The material is really solid on these so I dont see how it could be, but I thought I'd ask just in case.
If it is the seals, Is it a simple DIY job? I haven't really looked into doing it but assume I remove the screens and just get something like a hook to pull the rubber out?
Thanks guys
Thanks guys
