Faema Due - $100
  • ozscott
    There might be some useful information (generally) here
    http://coffeesnobs.com.au/brewing-eq...out-350-a.html
    ps. They are an awesome machine
  • SteveCoffee
    Help with replacing heating element in my Faema
    Hi all, Ive got a fame machine and need to replace the heating element ....... is there anyone out there that would be interested in showing how to replace an heating element. I'm an electronic engineer and would love to learn how to repair/rebuild my own machine. Can anyone help. I'm based in Doncaster in Victoria. Happy to use Skype if you can help but are interstate. Many thanks, Kind regards, Steve
    Great idea for future reference 'gc'...
  • greencardigan
    Link to my photo gallery for this machine.
    https://goo.gl/photos/ynMQk4c2ZRHj6yhJ7
  • greencardigan
    Just wrapping up this thread...
    I sold this machine a few months ago for $300. All up I spent around $50 in parts on top of the $100 purchase price. I believe it was heading to a fast food shop in Nowra for temporary use.
    Was sad to see it go, but I've just picked up an almost identical machine in a similar condition. New thread starting soon.
  • LeroyC
    Nice work. And nice rosetta!!! It's starting to all come together.
  • greencardigan
    I got a few new steam tips from CoffeeParts. A three hole and a two hole both with the same hole diameter as my existing 4 hole tips (1.5mm?). I'm finding the 2 hole tip very manageable and have some latte art happening again. Haven't tried the 3 hole tip yet. The threads on my steam wands don't quite match the new steam tips so they've been a bit troublesome to get on. I suspect my steam wands are not original.
  • 260zman
    Hey brad,
    Well done, you've been ticking the issues off one by one. Great diagnosing too.
    No luck with panels yet, although I've just used some jb weld kind of stuff to fix up the cracks. I've also toyed with the carbon fibre idea, but I haven't got past the watching YouTube vids on how to make the molds etc! I figured that gluing up at least one good set of originals would be a start towards making a mold.
  • artman
    With the steam, it's not just the number of holes but also their size (total area).
    I have used a 4 hole tip with 1mm holes and it worked great for microfoam.
  • greencardigan
    These look like a good alternative too. Metric Grip Rings For Shafts Without Grooves
    I added a small spacer (maybe 3mm) in front of the steam valve spring and it no longer leaks. I think it probably needs reseating ideally but the spacer is working so I'll leave it be for the moment.
    Justin, any progress on replacement side panels? I have been investigating making some carbon fibre panels or possibly just carbon fibre skinning the broken panels.
  • 260zman
    Originally posted by greencardigan View Post
    Does anyone know where I can source these spring clip things? They clip around the plastic standoffs on the front button panels to hold it on. I'm missing three.
    [ATTACH=CONFIG]12001[/ATTACH]
    Try these,
    I need some too and we've got an account with them Comac
    Sorry mods, I hope this wont breach website rules?
  • 260zman
    I've been getting some really excellent extractions from this machine! I'm using the single basket from my Breville BES920 with my usual grind and dosage but the Faema extraction seems a step up from the BES920.
    I'm still mesmerised by the steam volume! Anything I can do to make it more manageable?
    yep, heaps of steam!! its great.
    there are a few different option steam nozzles available. on my daily machine I have one steam wand with 4 holes, which I use for larger quantities of milk, and the other wand has 2 holes, which seems to have a lot less grunt (makes it easier to do small amounts).
    Also what is your boiler pressure at? if pressure stat is set too high, my understanding is you will have more steam pressure. This really needs to be set by measuring the water temp coming thru the group though, as you don't want to reduce the temp/pressure to the point that it compromises on extraction quality.
  • sprezzatura
    Originally posted by Dimal View Post
    Perhaps a Circlip of the right size might do the job...
    [ATTACH=CONFIG]12004[/ATTACH]
    Hey! My La Marzocco steam wand circlip! Been looking for that everywhere since launching it during a overhaul.
  • greencardigan
    A few 15mm binder clips borrowed from work has done the trick.
  • dumiya
    Actual purpose not clear. I am thinking you could make one considering the patience and skills you have demonstrated. Is it just a flat disk or does part of it go through the panel. Is there one or are there a lot of then required. It's design is quite clever but I have not seen one before.
