Hi All,
I have a little problem with my plumbed in Cimbali Junior D.
My machine is permanently switched on and the brew pressure is 9 Bar (checked).
Since a few months ago, when I didn’t use the machine for a few hours and did a cold flush, only by the second flush, did the water came out. However the Ulka pump worked from the start. I opened the machine and found a leak by the level glass. I changed the 2 EPG gaskets (no Viton available), and the problem was virtually solved. Next day the problem started again, and no leaks by the level glass. I descaled the group solenoid and changed the little O rings (Viton). But the problem persists.
Does someone (perhaps Super Moderator Javaphile…) have an idea what the problem is could be?
Cheers and thanks in advance.
Rodrigo
Rodrigo
