Hi guys, I've had my Rocket Evo v2 for over 1 year now, bought brand new never had any issues with the machine.
I regularly black flush and always makes sure to properly flush steam wand, and am very careful in general.
This morning went to top up the water tank, and then when I went to pull a shot, the pump started but then immediately stopped. I Was confused and took the portafilter out and went to look at the grouphead and then pulled the lever again, same thing, i hear the pump start but then it immediately stops, and the green light blinks twice and then goes solid again.
I turned it off immediately, and went to read the manual couldn't see any error code for 2 flashes then solid.
I did observe the pressure gauge the second time around as well and noticed it flicked up very slightly then fell down as the pump stopped.
Boiler pressure was good and steam production was fine, I'm assuming it is a pump issue but i don't what's causing it!
Any help will be much appreciated! cheers!
