Slayer Vaporizer
  • Slayer Vaporizer
    Just when you thought the Slayer couldn't get any better.
    https://www.beanscenemag.com.au/news...c87b-136606450
    And welcome to last week...
    http://coffeesnobs.com.au/showthread.php?t=44345
      Welcome to this week with a link
        Now let's hope for a V4 of their flagship model with these vaporizers!
        And a "Barista Dashboard" option as well because those looks so much better than that touch screen on the flagship model!
          I'm not sure they will do that. You'd then have two identical machines with different bodies.
          The Slayer steam was developed with different intent and to allow choice.
            Not really, the Steam does not have flow rate control like Espresso does and there's nowhere near the amount of appearance options as the Espresso has.
            Slayer Steam will also be at a cheaper pricepoint, less options/trim levels and less "fine tune" of your shots.
            I get product segmentation but at the same time it doesn't really make sense that the flagship model has inferior steeaming capabilities compared to a cheaper model in the lineup.
            It also doesn't make sense to require people to buy both machines just to get their flow rate control and their "revolutionary" new steaming capability. Most people doesn't have that kind of money so most likely they'll go with the Espresso model because that type of fiddling is more important than "the best steam" - in that case their new machine has been developed in vein since no one will buy it..
              As one of the 2 Importers into Australia for these machines and the only person in the country to have actually seen and used the Slayer Steam i think i may be qualified to answer your questions.
              In most espresso machines, steam boilers produce a saturated steam, high in moisture content, which measures barely above the boiling point of water (212ºF/100ºC). This conventional process brings milk to a pleasant temperature that elevates flavor over that of cold milk.
              The Slayer Steam Vaporizer removes moisture and develops milk flavor at even higher temperatures. With hotter steam (heated to 162ºC and up), we begin to affect the milk on a molecular level. Caramelization and Maillard reaction transform milk sugars and proteins into more complex chains, developing new levels of sweetness and creaminess. These positive effects also extend to dairy alternatives, which yield truly decadent results.
              Then there is the Accu-Flow Steam Actuator that ultimate control of steam flow, offers 2 programmable steam flow presets at each wand, for a total of 4 on the machine. Throttled flow improves control when preparing small volumes of milk for macchiatos and cortados, whereas 100% flow may be best for lattes. These settings also allow for fine-tuning of dairy substitutes.\
              As to them building this machine in vain and nobody buying it i can say that as one of the largest distributors worldwide we are out to November with orders with the first 2 shipments mostly pre sold.
              Any enquiries or questions feel free to pm me
              George
                As I would expect. It's a status item - they'll sell! I think I'd do the same thing - release the technology into a separate model to avoid any risk of tarnishing the Espresso, then give all those jealous Espresso owners a tried and tested reason to upgrade to a new Espresso/retrofit.
                  Terms like "begin to affect the milk at a molecular level" is meaningless marketing speak.
                  You're really saying it heats a portion of the milk to very high temperatures, resulting in caramelization of some of the sugars. It would be interesting to know if Slayer (or others) have demonstrated this analytically, or if it's just a theory.
                  Just a few comments:
                  - steam boilers are pressurised, so the saturated steam can be (and usually is) >100°C - you just can't heat it to greater than than the boiling point of the liquid (while the element is immersed).
                  - with saturated steam, any heat loss (such as in the steam piping) results in condensation and a reduction in steam "quality" (quality being industry jargon for vapour fraction).
                  - in the Slayer Steam, I'd hazard a guess that saturated steam from the boiler is passed through a superheater on it's way to the wand. In the superheater, any liquid is vapourised. Once all of the liquid has been vapourised, any further addition of heat will increase the temperature to greater than the boiling point (this is called "superheating" ). Subsequemt loss of heat in the downstream piping will reduce the temperature but won't result in liquid condensing unless the temperature falls to the boiling point.
                  - When you open the tap, the steam cools rapidly. If the steam is sufficiently superheated, it will dissipate in the air before it condenses (so you don't see it). With saturated steam, liquid will condense immediately, and it is this liquid that is visible.
                  - saturated steam and superheated steam are both 100% water.
                    Not all liquid is vaporised with the Slayer - it's just about 35% drier. So instead of 150 mL milk typically diluting to 165 mL after steaming, you'd get about 160 mL. Slayer says that makes a difference to perceived sweetness, but I do find it hard to believe. As those who have used the Steam model seem to unanimously agree the milk is sweeter, the 180 odd they heat the steam to seems more likely responsible.
                      Do they say the steam is 35% drier, or that 35% less water is added to the milk (very different things). I've seen claims it produces dry, superheated steam (and a video which seems to support this claim).
                      You can't have superheated wet steam.
                        Crikey! ain't this riveting stuff, guess it has meaning for them that's obsessed with steam in all it's forms.
                          They say drier steam watering down the milk by around 6.5% instead of the 10% typically found on other machines. I wouldn't get too hung up on wording though - the product is aimed at baristi, not scientists. I would consider 5 mL less water in the cup being drier as legitimate marketing.
                          Agree that you can't have superheated wet steam, but remember we're not looking at an snapshot of the steam at one particular point in time but flowing through a vaporizer over say a 20 second period. The vaporiser might need to rely on being preheated so that only the steam early on can be given enough energy to come out of the saturated state. If steam exits at the claimed 180°C, then it is superheated.
                          But that might be just initially.
                          The new 120°C steam coming in from the boiler however might be cooling the vaporiser beyond what the heater can instantaneously restore, leading to simply less saturated steam. The milk in otherwords sees increasingly wet steam over the steaming period.
                          The resulting 35% less water in the cup suggests not much is superheated, especially as the saturated steam portion would be less saturated than what we normally see. That arrangement would also be ideal for steaming milk where the lower heating ability of less saturated steam (especially superheated steam) gives more time for aeration before the milk's too hot.
                          Anyway, that's purely my guess to encourage discussion. All figures I have indicated however come from Slayer.
                            Very interesting. By the time I've saved up to an Espresso, I hope they brought over some steam-features from the Steam model!
                              No, it isn't. Driness has a very specific meaning with respect to steam. It has no meaning with respect to milk (which is after all, mostly water). That is how dogma is established, and that is generally not a good thing. Do you refer to full cream milk as being drier than skim? No. Enough said.
                              How much the milk is diluted is only indirectly related to driness anyway - what matters is the specific enthalpy. Higher specific enthalpy of the steam = more heat available per gram of steam = less steam required to heat milk to the same temperature. The liquid component of wet steam has much lower specific enthalpy than the vapour. Simple.
                              In any case the marketing material I have seen states that the steam is dry, so you dilute the milk less. The claims around the effect of higher temperature are questionable, and I suspect the advantage of superheating is mostly related to keeping the steam dry once it has left the superheater.
                              This doesn't seem likely. Much less heat is required to superheat the steam than what was required to boil it in the first place. Slayer claim you can adjust the steam temperature - which doesn't suggest an underpowered superheater to me.
                              A quick back of the envelope calc suggests that in an idealised case If a typical espresso machine supplies saturated steam at 125°C with a quality of 90%, you need around 9.4g to heat 100g of milk from 4°C to 60°C.
                              Using steam superheated to 180°C instead, you would only need around 8.2g of steam. That's about 13% less water added.
                              In fact, for superheating to achieve a 35% reduction in the amount of steam required, typical saturated steam would need to have a quality of around 64%. I'm quite certain the steam coming out of my wand is not 36% liquid.
                              l don't think that the quoted 35% reduction in steam requirement suggests there "not much is superheated"...
