ACS Vesuvius - Power Requirement
  • ACS Vesuvius - Power Requirement
    Hi Fellow CSers,
    Does the ACS Vesuvius require a 15 Amp GPO? I'm currently currently considering this as my next upgrade. Thanks.
    Jason.
    It's 10A Jason
      Originally posted by Talk_Coffee View Post
      It's 10A Jason
      Thanks Chris. That does make things a whole lot easier. I'm guessing not all 2300W is drawn at the same time? Calculate current draw for 2300W works out to be
      2300/(0.8 x 230) = 12.5 Amps.
        No need to use a PF of 0.8...
        90% of the load is resistive.
          Thanks for pointing that out Mal.
          Assuming 100% resistive load, the power factor would be 1. Making the current draw at exactly 10 Amps. Would that be correct?
            The machine is protected by a 10A fuse.
              Thanks Chris. Thanks all I need.
                In a perfect world, yes...
                  Keep in mind the Vesuvius remains in standby mode if you plan on using the built-in 7 day on/off timer. In which case it wouldn't hurt to add a little surge protection. I'm running one of these between my Vesuvius and the GPO (Thor C2 - Smart Filter Duo) - better than nothing I suppose...
