I grabbed a Azkoyen Vienna two group from a backpackers this morning. Listed as not working with an electrical fault.
It's in really quite good condition externally. Dirty inside by the looks, only did a quick inspection under the drip tray. Sparkling compared to the Boema though.
It looks to be 20amp single phase or something along those lines. Like a 15 amp earth pin on all three pins. I'd rather it run on 10 or 15amps so I might look into a lower watt element. Mind you, it looks as though the machine has a two or three stage element so it might be a simple case of disconnecting a leg or two.
All push button controls so there's a chance they could be stuffed.
I'll know more as I go, just wanted to know if there's anyone with experience with these machines.
Sam
Sam
