Problem with la marzocco on 2 groups
  • loveflies
    yes, they are a great team, I had also done the boiler descaling and steam extension adjustment. the machine is like a new one now, really happy and can't wait to open the shop
  • matth3wh
    That's great Angus! Plus you know your machine is checked and ready to go and is right to start helping make your business some money. I'm sure the Boiling Point team would also have helped to make sure you had correct filtration as well.
    Good luck with it all.
  • loveflies
    Problem solved, had a tech from boiling point visit, it is actually normal, thanks to anyone who paid attention to this thread
  • loveflies
    Thanks EspressoAdventurer will give it a try =)
  • EspressoAdventurer
    Loveflies there's a PM there for you. Re: Tech
  • loveflies
    Thanks matth3wh, I will definitely get everything ready to serve you��
  • matth3wh
    Sounds good. All the best with the repair.
    Let us know where we can come to taste test the coffees when you open.
  • loveflies
    Had la marzocco tech call me this morning, he suggest might be the build up scale in the gauage pipe so the gauage didn't really tell the truth, or maybe the faulty pump, I am getting the tech to visit and try to fix it
  • loveflies
    I had try a month ago, they supposed to call me back but not, anyway I had just E-mail to them and will give the feedback if I have answer
  • matth3wh
    Hi Angus
    They're beautiful machines. As it's so new it's worth simply phoning / emailing La Marzocco tech support details via their website &/or one of the resellers to clarify.
  • loveflies
    anyone? Or this is actually normal? I never use the 2 groups anyway
  • loveflies
    started a topic Problem with la marzocco on 2 groups
    Hi guys
    I am test driving my secondhand 2015 la marzocco PB 2 groups at home before my café open, but found a problem, had bleed the machine, and change the bar pressure to try fix it, but no luck, the problem is when I pour the water with no coffee in the group on group 1 the bar will drop from 12 to 8 but when I pour the water with 2 groups together the bar drop to 3, I had check with different la marzocco 2 groups it's should be not lower than 8 bar when both groups pouring water, I tried to give more pressure by adjust the rotary, but still drop around 3 bars when both groups pouring, any ideas?
    When both groups have coffee inside, they seems running OK with 9 bars.
    Sorry for my English, it's wasn't my mother language, if I didn't described clear enough please check the video below, thanks.
    https://youtu.be/31dGlGBYOkU
