Just remember though, that this is a fairly meaningless specification on it's own. Yes, it's 2 bar, but the boiler is very small at 1 litre. This means the pressure falls away very rapidly as soon as you release steam. It's not going to steam as well as the machines with 2+ litre boilers
True in some respects, but if the water level, element rating and PID Control are optimised as a system to maintain steam production then this won't be noticeable with normal usage...
The 2bar steam pressure is also better than most other DB machines.
With the various deals out there on Hx machines, the Profitec Pro 600 may struggle for traction in the marketplace though at the price point of approx. $3400. I suppose time will tell.
I believe that it would be taking sales away from the Pro 700/ECM Synchronika type machines, as this does pretty much the same thing at a much cheaper price. The 2bar steam pressure is also better than most other DB machines.
These machines are out there now and available for purchase. They sound ideal for the lower volume user who doesn't require a large dual boiler with their larger steam boilers. Seems to sit in the higher end Hx machine area of the market but satisfies the additional requirement of more precise PID control of brew water temperature in the dedicated 750ml brew boiler as well as individual PID temp control of the separate 1L steam boiler.
Specs look good. Have to wait for final pricing which could determine level of interest I guess.
Same size as Profitec 500 but a Dual-Boiler - 0.75L SS Brew boiler + 1.0L SS steam/hot water boiler both with 1000W SS heating elements and individual temp control. https://www.profitec-espresso.com/en...s/pro-600.html
Dual boiler (single boiler option)
E61 brew group with stainless steel bell
PID-display for the individual temperature adjustment of both boilers
PID-display indicates the brewing time in seconds
Manually adjustable brewing pressure
Programmable ECO-Mode
Brew group cleaning reminder
Wear-free rotary valves
Vibration pump
2.8 l water tank
Automatic shut-off when machine reaches low water volume
0.75 l stainless steel coffee Boiler
1.0 l stainless steel steam and hot water boiler
Boiler insulation
Boiler and pump pressure gauges
Stainless steel 1000 Watts heaters
Removeable cup tray
Weight 24 kg / 53 lb
Dimensions W x D x H:
305 x 450 x 395 mm without portafilter
305 x 555 x 395 mm with portafilter
