ECM Technika V - Weak steam pressure
  • #16
    That makes the profitec better in regards to steam pressure for the given group temp, but it doesn't have a rotary or shot counter which eliminates it for me.
    • #17
      Aintmissb - the 4 hole steam tip for the Technika Profi V produces more powerful steam pressure because a) there are double the holes and b) the holes are in the order of twice the size. ie a serious improvement. With the PID setting at 125 I have steam pressure starting at 1.4 bar.
      Charlie - The temp chart given in the manual gives a confidence to novice users which is unwarranted on a couple of counts. It implies, to me, the temperature is at the portafilter AND that it will be a sustained temperature. Neither is the case. As I understand it the temp given is likely to mean a reading where the thermometer can be screwed into the GH and it is not explained that the temperature at the portafilter will be 1.5 to 2 degrees lower. With my PID set to 125 here is my recording of one draw:
      Seconds 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
      Draw Temp 89.4 90 92.8 93.9 94.9 95.4 95.7 95.7 95.2 95.2 94.6 94.6 94.3 93.9 93.9 93.8 93.7 93.7 93.6 93.6 93.5 93.5 93.4 93.4 93.3 93.3 93.2 93.1
      The flush temp went, over 7 seconds, from 90.7 to 96.5. A lot of the draw would have been dropping, at the portafilter, from 93.5 down to 91.5. If I had waited for full temperature and gone straight into a draw it would have started at about 98 degrees and burnt the coffee. In this example the machine hadn't reached full resting temp.
      It shouldn't be so complicated, but with Hx machines, you can't get around it.
      What would be more helpful would be if the likes of ECM simply provided a more in depth chart which included flushing and recovery times per PID setting to reach X Average temp at portafilter. These are incredible machines and a major investment. I think there is room for improvement in the operating manuals, which tend to be way too minimalistic and, in the case of the PID charts, not overly accurate
      • #18
        I’ve upgraded to the 4 hole tip and set the PID to 125.
        I give a 5-6 sec flush with the machine at full temp before pulling a shot and I’m now getting good results.
        • #19
          All very interesting posts. I changed PID to 125 at first, then was concerned about a too high GH temperature and backed it off to 123. Steam pressure was about 1.4 bars at 125, 1.2 bars at 123. Steaming milk is OK, but I wouldn’t say that there is tons of steam available. According the the manual, which Jet Black Espresso posts, I should be at 95.5 GH temp for extraction, which is OK. I have the 4 hole steam head but haven’t tried it yet. I like the quester data too. Anyone have a clear idea how moving from GH 94 to GH 95.5 say, affects the taste of the espresso? Merry Christmas from snowy Ontario to all baristas!
          • #20
            Quick postscript: My steamed milk quality has seemed off for a week or two and I decided to descale the Technika. Pretty elaborate procedure since you have to unscrew two panels on the top and disconnect the “measuring rod” that sits on top of the boiler. But, having done all that, found that my steam boiler pressure at 124 degrees increased to 1.4 bars. Pretty surprising, but I like it. Needless to say the steamed milk is also working out much better.
            • #21
              So, having been enthusiastic about the 4 hole tip steamer in post #17 above, I have had a change of heart and gone back to the 2 hole steam tip. What I found, with the Technika Profi V PID set to 125 was the steam pressure dropped to .5 bar and that this was simply not enough pressure to properly foam the milk. The resting steam Bar pressure doesn't relate to steam performance. By raising the PID to 126 and switching back to the 2 hole tip, my steam pressure is now circa .7 Bar. I wish it was a little higher but it is doing the trick much better. I'm stretching to 38degrees C and heating the milk to 60 degrees.
              • #22
                Quester, I have been following the same path as you. I also purchased the 4 hole steam tip partly based on your feedback. I did not install it until a few weeks ago, but like you I just went back to the 2 hole version. I found the 4 hole tip does steam much faster, heating the milk to temperature in about half the time. But, it is very hard to control to produce consistent even micro foam. I always found an excess of air bubbles getting into the milk, particularly towards the end of the steaming sequence. Tried turning the PID temperature down, from 124 down a degree or so every day until I was back to the factory settings of 121 (might have been 120). This helped some with the air bubbling, but also lowed boiler steam pressure (to about 1 bar or so). So, finally decided to pack in that path, back to 2 hole, and raised the PID back to 124 again which has nice boiler steam pressure of about 1.4 bars. And now I feel much more in control of the milk stretching process and can (occasionally) produce smooth even micro foam . Biggest mystery to me still (I realize this is unrelated) is how descaling the machine produced about .2 - .3 bars of steam pressure - doesn’t seem credible!
                • #23
                  Hi all, sorry for being so absent on this post.
                  Just want to let everyone know the issue is now fixed! 😁
                  I didnt end up getting a 4 hole steam tip, but I did get another 2 hole steam tip with bigger holes.
                  Steaming milk is now incredible, the difference is night and day. Always producing a micro foam with ease and super quick.
                  No need to turn up the temp on the PID either, I've set it back to the factory setting of 121. Machine sits on 1.1Bar and when steaming it drops to around 0,6 - 0,07 Bar.
                  Anyone here that's still experiencing the issue I highly recomend you give the 2 hole steam tip with bigger holes a shot.
                  • #24
                    Demonstration of steaming milk with new steam tip...
                    • quester
                      quester commented
                      Editing a comment
                      Great video Pete. Glad you've found a way to harness the V!
                      Would you mind quantifying what you have achieved here, for the sake of those still struggling with steam pressure tweaks for this machine?
                      Mine took around 55 seconds to get 200mls from 8 degrees to 60 degrees with Trim milk to a mediocre foam with the PID set to 126 with supplied 2 hole tip. I would also purge, as required, then wait until the boiler temperature nearly reached back up to the PID setting so that the element would remain active and the steam be the maximum pressure available for that setting [milk ought to be 4 degrees from the fridge but by the time it settles in the jug etc it was averaging around 8 degrees before starting steaming. As dibbnz stated below, there is quite a wet purge to start with before getting down to business]
                      At issue here is whether there is a service tweak needed on a batch of these machines. Whole milk was producing just satisfactory results but Trim had me really working to get the microfoam. Switching out to bigger steam holes and raising the PID still just ended in the Bar pressure dropping during the steaming phase to the point where it wasn't enough to produce the result needed. Maybe having, say 2 x 1mm steam holes instead of the 2 x ?.8mm holes is the solution. Certainly, going to 4 x 1mm holes just dropped the pressure too far.
                  • #25
                    Hi all, and thanks for the update Pete7.
                    i bought one of these machines yesterday!!
                    I’ve only steamed 2 drinks, but the second one I noticed, initially the steam pressure was practically, non existent...there seemed to be a lot of condensation in the wand that took 3 good purges and a wait time of 20-30 secs between each one, during the purges the temp dropped down to 50C, does this sound right to you?
                    initially, I went to buy the expobar minore, but after a test run with my own beans, I was not happy with the taste, very thin with no body...they were testing the ecm for another guy, I tasted the coffee from that and it was like night and day, so I bought the ECM instead...unfortunately I didn’t get the chance to test run myself, I’m wishing I had now...no experience with PID and how it actually works, but I can see a thermometer purchase coming up lol
                    • #26
                      Quester and dibbnz, I recommend giving the 2 x 1mm hole steam tip a go, I do think it’s the solution to our problem. No service tweaks needed.
                      My morning routine with the machine after switching it on is to give it a good half hour until it warms up. Followed by flushing 500ml water out of the tank (from the hot water lever) so it fills up with new water. Wait for it get back up to temp (121 on the PID) and then open the steam lever for about 1 minute. Wait again till it get back up to temp and repeat for another minute. I find that this process builds up better steam pressure. I did the same process even when I had the stock steam tip and found it helped a bit, but now it’s much better with the new steam tip. I've done another video showing where my gauge sits with purging, see below.
                      Quester, it’s always hard getting a good texture with trim milk, barista’s always recommend using full cream. Most trim milks actually have more sugar than full cream. My local bakery sells St David's full cream milk, which is fantastic for milk coffee's. I find that St David's and Riverina full cream milk is like the perfect marriage for latte's, compliments the flavour of the coffee and doesn’t overtake and make it taste 'milky'. Most cafes that take pride in their coffee use these 2 brands of milk.
                      The video below I'm using St David's full cream, I'm always getting a beautiful creamy texture.
                      • Mike323
                        Mike323 commented
                        Editing a comment
                        Pete, I just bought a new Technika V and the steam tip looks identical to your original tip. The holes measure 1mm in diameter. So would you be able to confirm the diameter of the holes of the tip you bought? It looks more like 1.5mm comparing in the above photo you provided.
                      • Pete7
                        Pete7 commented
                        Editing a comment
                        Hi Mike, I just checked now and I can confirm that the steam holes measure at 1.5mm
                    • #27
                      Thanks for this Pete. I am new here, and I have a new ECM Technika V PID and have been surprised by the steaming compared to my Profitec Pro500. Can you tell me where you sourced the 2x1mm hole tip? I have been searching online and not found it. My supplier has suggested that he can get a 3-hole ECM tip, but I like the sound of your solution. Thanks!!
                      • #28
                        You might find that removing the anti-burn Teflon tube increases available steam pressure.
                        It's a reversable mod if you don't like it (or suffer too many burns)
                        • #29
                          Get in touch with Coffee Machines Technologies 😊
                          • #30
                            Hey guys! Hope all of you are well. I have had the Technika 5 for 2 years now and been reading through this thread. I've never managed to get sufficient froth with this machine. I've bought the 4 tip hole (the holes are also much wider). But still no results. I've increased the temperature of the PID, I've taken the machine to service. I've tried 10 different types of milk. I though( that maybe my frothing game was out of wack... but I tried my friends coffee machine and the first cappuccino I made was just perfect. I'm out of options now. Will probably sell it and move to a different brand...
                            • sacsnob
                              sacsnob commented
                              Editing a comment
                              Try removing the teflon tube inside the steam wand see if it makes any difference. I own a Profitec Pro 500 (similar to Technika boiler wise) and I find the steaming a bit underwhelming too.
                            • quester
                              quester commented
                              Editing a comment
                              sacsnob's comment came too late for me to try. The 4 hole tip lets out too much pressure and the standard 2 hole tip has holes which are too small. A solution from another contribute to try, as well as sacsnob's, is to drill out the 2 hole tip to 1mm..... ie if the holes are currently1mm then take them to 1.5mm. Should be quick and easy to do.
                              See Pete7's Excellent post just above. Great advice and input from him.
                              The Technika is a really well built, quality machine but this side of it has caused a lot of people grief. These two solutions may help. It is so disconcerting when you know your technique ought to be producing better foamed milk. Personally, I gave up and went for the Bezzera Duo DE. Haven't looked back...Love it.
