Boema Rebuild and Modification
Anti-vac valves should be replaced each service. Safety valves can last a bit longer, but be prepared to replace them as well. I’ll see if I can find some photos of my Boema and upload some photos later today of the piecework.
Can anyone confirm that this is the correct order for assembly of the water charge unit?
Also are these brew tanks over pressure valves reliable or should I swap it for a newer/better part?
I have pulled apart and cleaned thoroughly my single group Boema and wish to get it operational prior to making some modifications and upgrades.
I didn't take sufficient photographs of the pipe layout, is anyone able to check the attached images to ensure I have laid it all out correctly.
Tags: None
