LaCimbali M27 Selectron, please help
  • LaCimbali M27 Selectron, please help
    Hey Guys,
    I've recently rebuilt a Cimbali M27 Selectron following descale etc and am having problems with the controls as if its gone into some sort of reset mode or something. Its a 2 group machine and the only way i can get water to come out is by pressing the left and right buttons at the same time. then water comes out of the right group regardless of which button set you pressed.
    I have tried programming it using the procedure used on the M30 which doesn't work
    Does anyone have any hints or tips or a manual?
    thanks
    Stu C
    Have you tried this manual yet?
    Java "One more option" phile
    Toys! I must have new toys!!!
      Have you check the ribbons are connected correctly, if either group is turning on the same group, you could have a connection back to front
