Restoration of a Faema Lambro
  • #76
    Wiring is done, nothing much has changed in my tools outside of a few M6 ring terminals needed for the heating element. I had a cord grip installed and for under the drip tray I threw on some heat shrink insulation.
Name:	lambro wiring tools.JPG
ID:	884130 Click image for larger version
ID:	884134 Click image for larger version
Name:	power plug assembled.JPG
ID:	884131 Click image for larger version
Name:	cable terminals.JPG
ID:	884133 Click image for larger version
Name:	cord gripper.JPG
    • #77
      We're ready for testing! Now I just need to gather the courage to fill up the boiler and actually turn it on
Name:	power switch.JPG
ID:	884138 Click image for larger version
Name:	switch wiring.JPG
ID:	884139 Click image for larger version
ID:	884136 Click image for larger version
Name:	cabling done side.JPG
ID:	884137 Click image for larger version
Name:	element wiring.JPG
      • #78
        I fired it up this afternoon. I did an initial heatup to just pressurizing and turned it off, drained the water, waited for the machine to cool to room temp, tightened/realigned pipes, and did a second cycle. I was able to get to operating pressure (about 1.4 bar) but leaks are still plenty! Just to list a few:
        Manometer
        Both thermosyphon group fittings
        Water level fittings (both of them)
        Water inlet pipe (on both ends)
        Hot water pipe
        Possibly the boiler lid? That may be from the first cycle when some water got in the boiler rings from a fixed leak but will be scrutinized.
        The boiler was easily drained with my little valve inserted on the bottom of the water level. The leaking fittings suck but hopefully they can be addressed.
Name:	test bench.JPG
ID:	884143 Click image for larger version
Name:	pressurized manometer.JPG
ID:	884144 Click image for larger version
Name:	possible leak boiler.JPG
ID:	884145 Click image for larger version
Name:	leaking p-stat fitting.JPG
ID:	884147 Click image for larger version
Name:	leaking thermosyphon fittings.JPG
        • #79
Name:	leaking fittings.JPG
ID:	884151 Click image for larger version
Name:	leaking manometer.JPG
ID:	884150 Click image for larger version
Name:	draining boiler.JPG
          • flynnaus
            flynnaus commented
            Editing a comment
            It's like reading a good book, isn't it? You can't wait until the end but when it arrives, there's a feeling of it being over soon. Fortunately for us, IamOiman has a few other projects going. If Andy ever planned on a CS contributor of the year award, you'd certainly be in the running.
          • IamOiman
            IamOiman commented
            Editing a comment
            My first request if I received that award is to increase the maximum photos I can insert per post! I'd love to get them all in a single post rather than multiposting every 5 pics!
        • #80
          The leaks are mostly patched up but a few stubborn ones remain. The Thermosyphon loop seals now, and It's much better from the original heat up when almost every fitting was leaking! It's just the manometer, a lower pipe to water level fitting, and the water inlet I note as hissing or leaking. There is also a slow leak from the hot water valve. Finally I need to fiddle with the vacuum valve as it's not seating correctly.
          The gurgling occurs when I pull down the lever because there was no water circulating in the thermosyphon loop, so that sound is the water rushing into the pipes.
          I will keep doing heat cycles and adjust so I can flush out the insides of whatever grime or chemicals could remain. The chrome pieces were washed when I got them but you never know! The first shot is coming!
Name:	prepping for flush.JPG
          • #81
            I think I cycled enough water through the boiler so I got ready for the inaugural shot.
ID:	884294 Click image for larger version
ID:	884291 Click image for larger version
Name:	PF locked.JPG
ID:	884293 Click image for larger version
            The shot looked a little squirty but it was GOOD, like shockingly good. I just used my grind setting for my Bosco with 15g of Saka Caffè Crema Bar. I swear this is the first shot!
Name:	The First Shot.JPG
            • #82
              Awesome, after all that work! Well done
              • #83
                Excellent!
                • #84
                  I pulled one more shot today, it was a little overextracted but it was essentially liquid caramel.
                  Click image for larger version  Name:	2nd shot.JPG Views:	0 Size:	102.8 KB ID:	884309 Click image for larger version  Name:	2nd shot thicc.JPG Views:	0 Size:	109.7 KB ID:	884310
                  However that is not why I am posting. I found the source of the hissing, on the t-fitting for the water inlet and hot water solder joint. A pinhole leak 😐 (the greenish area right below the brass blob) . It is not consistent, often there is no hissing (even at operating pressure) but there are times where there is hissing and tiny bubbling occuring at various pressures but not room pressure. I noticed it specifically after I turned off the Lambro for the day and was observing it depressurized. No water escapes from the hole and evaporates instantly when it does occur.
                  I am almost afraid to ask if I need to take off everything to address this, it is a very small and not constant however I am not really wanting to do something like a jb weld fix if that is not really a good solution. However Loctite 290 might be a possibility for something so small. Or perhaps I let this tiny hole seal itself with scale? It can't be more than 0.5mm in diameter
                  Click image for larger version  Name:	the pinhole leak.JPG Views:	0 Size:	85.7 KB ID:	884308
                  • #85
                    Wow this is a first class restoration! Beautiful…. Suggest you take the boiler to a local workshop who can braze it for you. A good plumber would also be able to fix that.
                    • #86
                      I am just concerned with damaging the t-fitting if I take the brazing route. I'll admit I never was able to get it out, it was plugged beyond belief. Just to give perspective on the size, the hole is in a little 1mm divot that is maybe .25mm across if I look at it now with a measuring stick. Brazing or related would definitely fix the issue but it just seems like overkill for such a tiny leak? The rest of the joint looks sound after inspecting the photos, but of course looks can deceive. I can take off the pipes and everything but I'd never forgive myself if I mess that t-fitting
Name:	pinhole size outview.JPG
ID:	884323 Click image for larger version
                      • #87
                        Gee that's really tough about the T fitting. Have you seen Enrico Maltoni's Museum and website. He's restored some of the best around and written some really nice books too. Perhaps he might be able to give you some advice. Can't hurt to ask.
                        https://www.espressomadeinitaly.com/en/
                        • #88
                          incredible work - well done.
                          • #89
                            Maltoni can be hard to reach sometimes, he generally does not respond to questions like this but of course I can try 😂
                            There is also the suggestion to take a small punch or screwdriver to gently strike it once near the hole to push the solder a little to block the hole. I have a few options it looks like so I'll see what is appropriate
                            • #90
                              I believe I will try to go for the lower temp lead free solder as a solution since this will not be supporting the fitting but rather just focusing on the tiny pinhole. I was thinking something like this for the material, about 430F melting point. If I do this method I will try it first myself. I'll scrub off the surface of any scale/debris with scotch brite, wipe it down with acetone, then use a hand solder tool I have on hand to do the job and see if I need to escalate from there.
                              https://www.acehardware.com/departments ... ries/27155
                              The only question I would have is the cleanup of the flux after. I presume I would need to cycle some water in the boiler to clean it out or will it just burn away?
                              • IamOiman
                                IamOiman commented
                                Editing a comment
                                or rather with a propane or MAP Pro torch with a focused flame. Just realized how much mass I'll need to heat up for the solder!
