Identifying the manafacture date of my Giotto Rocket
  • roosterben
    commented on 's reply
    No PID just an internal pressure stat. I can't recall if PID was an option on this version.
  • Grumpybarista
    Has yours got the PID as well or just dual dials? Maybe the PID was v3
  • roosterben
    I have a Premium Plus V2 with the dual dials, mine is a 2013 model which I think is when they were introduced. Based on some googling the Premium Plus V1 was released in 2008, that would place that machine 2008-2012 (or early 2013).
    Lovely machines and still enjoying it 3 years on.
  • Carmine
    I totally agree with you Grumpybarista. It is a workhorse which makes lovely coffee as it is. I actually like the simplicity of the thing.
  • Grumpybarista
    Flying18, my Giotto Premium Plus V1 is over 8 years old now and it was a present to me by my wife. It has a vibrating pump and no real bells or whistles. Just a straight forward work horse that hasn't mised a beat, still works very good and I can make delicious, well extracted coffee.
    Rocket has made a number of similar machines with vibrating or rotary pumps and with other bells and whistles under different names. My dad has a Rocket Giotto V Cronometro espresso Coffee Machine and it's pretty much the same as mine 8 years later.
    In my own opinion, unless you want to change the pump pressure, or plumb one in, or stabilise the temperature with a PID they all share most of the same parts and you can make just as delicious coffee on the older ones as you can on the newer ones - new ones just appear to have more bells and whistles. Happy to be stood corrected by other Snobs if I am missed something.
  • Flying18
    Just wondering why did you pick Giotto out of the other Rocket range? how does it compare to the others?
  • Grumpybarista
    Yep Rocket Giotto Premium Plus V1 serial number on bottom and can confirm first 4 numbers are the year. I have that exact machine
  • EspressoAdventurer
    Good Info Flynn
    Agree with
  • flynnaus
    Originally posted by Carmine View Post
    No number behind the drip tray. Will have a look inside.
    Here you go: https://espressocompany.com.au/pages...number-locator
  • Carmine
    Thanks for that. Much appreciated. No number behind the drip tray. Will have a look inside.
  • flynnaus
    The first four digits of the serial number should tell you the year. I think from memory the label can be seen behind the drip try but I can tell you it is a Rocket Giotto Premium Plus V1 manufactured around 2008.
  • Carmine
    started a topic Identifying the manafacture date of my Giotto Rocket
    Have always loved the Giottos but only came across the beauty recently.
    Giottos have a very potted history which includes models which are not considered to be 'authentic'.
    So i was wanting to see if I could identify where in the history time line my machine falls.
    I have attached pictures to assist but i am also aware there should be a date on the inside some where. Is this correct and where would i find it?
    Thanks in advanceClick image for larger version  Name:	giotto 4 (2).jpg Views:	13 Size:	279.2 ** ID:	863312
