Yes- definitely worth leaving the keyboard to look at some gear if you possibly can.
Don't underestimate the value of local (competent) service and support. Your machine will thank you for maintaining it well and there are some seriously dodgy techs and operations out there. Most recently, I was advised of an episode where a tech who has recently worked on a linea mini (twice) and was unable to diagnose and attend to a faulty anti-vac valve on both occasions. I call that 100% incompetent [/facepalm].
Would also recommend you do some more research as there appears to be some confusion as to what you actually want/need. A pump is just a method of getting water to coffee. You only need a rotary pump if you want to plumb at some point. As to machine style, I suspect you will be happy with a heat exchanger (HX) machine. it doesn't sound like you need the extra complexity of a dual boiler machine.
Many resellers including CS sponsors have produced buyers guides to help you. Search espresso machine buyer guide and you're sure to find plenty. A good guide will help you come to a short-list of machines you like within your price range (which also requires a minimum $500 for a suitable grinder). Then speak to a few resellers to get some advice and recommendations.
Perhaps you might also come back here with a few machines you think might suit and then let us pick holes in your choices. In all likelihood, all will make great coffee. It's more about build quality, finish and liveability issues which may either sway you towards or away from a particular machine. That's how you find the right one for you.
Machine recommendation - $3000-$4000
You don't think that having access to local service matters? Or the ability to see a machine 'in the flesh' and try it out? You may of course, be in an area where you can't purchase locally, but who knows? Anyway, just trying to help. But whatever...
- Likes 2
Can purchas online, no?Originally posted by Barry O'Speedwagon View Post....and where you live.
It may be helpful to provide some background on your coffee experience to date, current equipment and your specific use case.
It's a wide open field in the $3k to $4k price range.
It will come down to your workflow, machine aesthetics and ergonomics.
The decisions will be between e61, lever machines and others. New or used. Hx or dual boiler.
I suggest starting with site sponsors and short listing machines you like the look of.
- Likes 1
Looking for some advice - I'm looking to upgrade to a new machine - feeling a bit overwhelmed with all of the choice out there.
I make mostly lattes and espressos.
Would prefer rotary, but if that's out of the budget - not too worried. Dual boiler or hx is also fine!
Thanks!
