Gaggia Classica 1 Group
  • #31
Name:	scratches backsplash.JPG
ID:	888252 Click image for larger version
Name:	cleaned inside backsplash.JPG
ID:	888254 Click image for larger version
Name:	cup tray cleaned.JPG
ID:	888253 Click image for larger version
Name:	cup tray detail.JPG
ID:	888255 Click image for larger version
Name:	cup tray inside cleaned.JPG
    • #32
ID:	888260 Click image for larger version
Name:	cleaned panel inside1.JPG
ID:	888258 Click image for larger version
Name:	cleaned panel inside.JPG
ID:	888259 Click image for larger version
      • #33
        I also found a way to disassembled the tap rods. Using some soft grips on my pliers and a 15mm wrench, I could exert enough force to loosen the threads. This will be good for cleaning as I smelled penetrating oil inside each one. Lastly, I can definitely fit some 3/8" fittings into two of the heating element holes as I plan to use a replica element that only uses two of them. One will be for the p-stat and one for the vacuum valve. I am ordering some extra tall 3/8" fittings to fit the holes.
ID:	888264 Click image for larger version
ID:	888263 Click image for larger version
ID:	888265 Click image for larger version
        • #34
          I did the same treatment/cleanup with the bakelite handles as I did with the Internazionale. However the lever handle is not bakelite, rather it is an actual plastic material. Therefore I did not polish it and instead just cleaned off most the grime by hand.
          I got my first parts order in, from Paul/Cafelat. For the Classica I got a 1500W 110V heating element + the boiler gasket. They fit nicely! For the studs I will use 45mm stainless A2/304 headless studs with the allen key driver (the ones pictured are a mix of 50mm studs and a 40mm stud while I was checking the gasket alignment). The nuts are extra wide brass M8 nuts that I sourced from a UK auto supply store of all places. They are 50% wider than the regular ones I ordered prior and should withstand more torque. The two extra holes in the lid I intend to try and install a p-stat pipe and a vacuum valve as I want to use the wobbler weight, which is the only boiler fitting not counting the four valves and group flange.
ID:	890402 Click image for larger version
ID:	890405 Click image for larger version
ID:	890406 Click image for larger version
          • #35
            I was hoping to avoid this issue but I gathered up the courage to actually check to see if there was a bend in the frame. Unfortunately there was. The rusted away screw is not aligned with its frame hole. Taking an edge you can see the gap on the right support of the frame compared to the intact left support! In fact it also appears the boiler-frame piece is slightly bent as well! I can push the boiler part towards the frame a little but one of the two definitely need to be adjusted. This issue appeared to have been present before shipment since it probably occured near when the rusted stud detached itself from the frame. Depending on how serious the damage is it may require sacrificing the old frame paint if heat will need to be involved.
            Good thing I am heading up to my metal guy to pick up the Internazionale boiler! He'll help me out with this issue.
Name:	straight frame.JPG
ID:	890422 Click image for larger version
Name:	bent frame.JPG
ID:	890423 Click image for larger version
ID:	890425 Click image for larger version
Name:	bent metal piece.JPG
            • #36
              Frame got bent back. The method used was placing a flat surface inside the frame and resting the bent portion of the frame on it while clamping it down gradually against the surface. Before bending it back, two cracks were identified in the frame that were also fixed with welding after the frame was straightened. In the process, I discovered the paint was not actually competely the cause of the brown color, but rather some of brown hue was from the original rusty frame underneath it, essentially the frame got surface rust and was painted over. I was hoping to keep the frame original but the discovery of the rust and the welds that already took off a portion of this paint and leaving exposed and unprotected metal resulted in me deciding to redo the frame coating. One of the original screws and a missing screw were replaced with modern stainless steel ones (the ones with the hex heads). Specifically the replacement ones I used are 90 degree countersink M8 screws and are just about the exact same size as the old ones on the head.
Name:	fixed frame.JPG
ID:	892086 Click image for larger version
Name:	fixed frame detail.JPG
              With the frame back I just had to check if the panels fit correctly. In fact they do . For this machine, the issues I am left with are ensuring I obtain the correct sized gaskets for the valves, and to figure out how I will fit a p-stat and vacuum valve without replacing the original wobbler weight. I purchased some fittings for the lid but the threads are not long enough to catch a proper thread with a seal/gasket.
              Oh also I pray the piston to rack connection holds up, that is my next biggest concern. Boiler leaks are also hopefully not a thing.
ID:	892088 Click image for larger version
Name:	backsplash fit 1.JPG
              • #37
Name:	back panel 1.JPG
ID:	892091 Click image for larger version
Name:	back panel top.JPG
ID:	892093 Click image for larger version
Name:	fitting all fitings.JPG
ID:	892092 Click image for larger version
                • #38
                  The helicoil repair is still ongoing, but I got the group assembled. First thing I do is insert the shutoff valve with the gasket. The group uses the modern 4 v-gaskets and 4 v-rings just like all my other Gaggia groups. With the stack in the group I then lubed the seals and inserted the piston with the spring and two brass sleeve pieces. I tightened the 80mm nut when I was happy with the initial piston height in the group (flush with the bottom sleeve).
                  Click image for larger version  Name:	shutoff mechanism.jpg Views:	0 Size:	97.6 ** ID:	912319 Click image for larger version  Name:	piston height.jpg Views:	0 Size:	96.4 ** ID:	912317 Click image for larger version  Name:	spring.jpg Views:	0 Size:	100.8 ** ID:	912315
                  With the the spring tool I started compressing the spring to a point where the rack was high enough that the teeth were fully exposed inside the upper group where the pinion is located. I could then insert the pinion, everything greased with my Kynetx grease. The bearings are new and are sealed. It can be inserted with a few light taps of a mallet. The cover cap goes on after.
ID:	912316 Click image for larger version  Name:	teeth rack in group.jpg Views:	0 Size:	89.1 ** ID:	912318
                  • Lyrebird
                    Lyrebird commented
                    Editing a comment
                    A better way to insert the bearing is to use a small arbor press and a collar that presses on the outer race only. Arbor presses are cheap.
                  • IamOiman
                    IamOiman commented
                    Editing a comment
                    ohhh I did not even think about using an arbor! I'll add it to my list of stuff I want to get down the road
                • #39
Name:	greasing pinion.jpg
ID:	912322 Click image for larger version
Name:	pinion and bearing on.jpg
ID:	912323 Click image for larger version
                  What I consider the most difficult portion of this assembly is next, installing the second bearing. It takes some precision to tap in the new bearing due to the tight tolerance of where the bearing is housed on the rack. I also brace the group so that the pinion absorbs most of the force from my mallet. If successful the second bearing cap can screw on. I could then install the preinfusion mechanism, which is easiest to do when the group is on its side. The little spring holding the steel ball is new. Finally the spring tool can be removed by locking the group in the preinfusion position (which I have to say makes a very satisfying click) to allow me to unscrew the tool and install the top nut and acorn nut. Adjustments for the lever position and piston height that shifts during installation will be done after.
Name:	bracing group.jpg
ID:	912326 Click image for larger version
Name:	installing 2nd bearing.jpg
                  • #40
                    conitinued..
Name:	2nd bearing installed.jpg
ID:	912329 Click image for larger version
ID:	912330 Click image for larger version
Name:	preinfusion ball1.jpg
ID:	912332 Click image for larger version
Name:	preinfusion cam on.jpg
ID:	912331 Click image for larger version
Name:	assembled classica group.jpg
                      Dimal commented
                      Editing a comment
                      Very nice work indeed...
                  • #41
                    It's been a few months since I posted about the Classica becuase I was tracking down two parts for it (a sight cover for the water level glass and the plexi). I also had to place a thread insert on a bad group thread.
                    Luckily the parts were sourced and finalized this week so I started assembling the machine in a temporary setup to check the integrity of the boiler and a weird little 5/16" 18 TPI screw that threads into the center of the bottom boiler 'arms'. I think it was added after leaving the factory but I need it to be sealed properly because I cannot access it when the machine is assembled due to the backsplash covering it. Used a fat wad of teflon tape to get that dealt with. I checked one more time that the boiler threads were in good shape and I used 30mm long stainless steel bolts that thread in nicely. The boiler lid itself has a workaround for the two extra holes on top since I only have one element installed. I added the vacuum valve to one hole which will be isolated from the heating element when fully assembled. The unused hole in the lid is just plugged and can be used for manual filling. Everything is 3/8" BSPP.
Name:	screw thread.jpg
ID:	928398 Click image for larger version
Name:	classic lower bolt 1_4 18 inch.jpg
ID:	928396 Click image for larger version
Name:	inside of lid.jpg
ID:	928395 Click image for larger version
Name:	boiler lid top.jpg
                    • #42
Name:	test rig front.jpg
                      In this state + later adding the lower drip tray I brought the machine upstairs, and even without everything installed it was an effort due to the weight, which is over 68 pounds/31 kilos with the drip tray. I had to reweigh a few times to confirm the huge mass but it makes sense why I struggled moving it! They don't make 'em like they used to :lol: I had my little bowls to catch any water and allow me to diagnose anything suspicious. Once upstairs I just hooked up a power cable directly to the terminals and enable power at my GFCI reset button.
Name:	68lb 6oz Classica.jpg
ID:	928405 Click image for larger version
Name:	test bed front.jpg
ID:	928403 Click image for larger version
Name:	test bed side.jpg
ID:	928404 Click image for larger version
Name:	wiring setup.jpg
                      • #43
                        The element itself is rated for 1500W 110V, and when I turned it on for the first time I was struck by two things: it heats up quickly (just over 10 minutes with 3 liters of water) and it is very quiet. Hardly any water came out of the vacuum valve and it sputtered for a second before sealing. It's a little weird to not see a manometer but I turn off the machine when the safety valve starts sputtering. I don't know what the wobbler weight is rated to start releasing steam but it is quite heavy at nearly 1.5kg. I was able to flush the group (without the shower screen to allow debris still inside to escape) to satisfaction and tightened all the bolts and gasket stack when the machine cooled down overnight. I turned it on again this morning to similar results and so far nothing is leaking from the boiler outside of the temporary fittings I installed.
Name:	first pressurization.jpg
ID:	928411 Click image for larger version
Name:	covering vacuum valve.jpg
ID:	928408 Click image for larger version
Name:	water flushed.jpg
ID:	928410 Click image for larger version
Name:	no shower screen.jpg
ID:	928407 Click image for larger version
Name:	wobbler weight 1491g.jpg
                        • #44
                          After changing the water out in the boiler I was almost ready for the first shot. However I needed to borrow a cafelat portafilter gasket from my Marte because it is the only one that will fit into the Gaggia Lever group without fighting me while also installing an IMS shower screen. The other gaskets are just too hard.
Name:	1st shot setup.jpg
ID:	928495 Click image for larger version
Name:	IMS screen.jpg
                          I waited 80 minutes for the group to heat up fully, and I pulled the first shot with the original portafilter. It tasted ok but the machine needed to heat up more and I needed to adjust the lever a bit. Unfortunately the video was not recorded properly but I at least have a pic of the shot.
Name:	First shot classica.jpg
                          I did take a 2nd video with better results, and after I adjusted the lever. In this configuration I need to do a Fellini pull but the result is something just great. I basically got a dark choco bar in the shot. You can also see how much space I have between the drip tray and the portafilter. I can easily fit my tallest cup with no issue. I am quite happy with the results but I cannot call this project complete until all the fittings and panels are installed.
                          https://www.youtube.com/shorts/lb9d1WZI2XQ
ID:	928493 Click image for larger version
                          • #45
                            I have tested the machine under pressure enough to decide the boiler and lower screw are sealed fine without issue, so I will take off the grouphead and front foot so I can install the backsplash then fittings. In prep for the full assembly I cut a pstat bracket from a 20 mm wide x 2 mm thick aluminum sheet, then bent to shape and drilled. I installed the big panel piece to make sure the pstat does not brush against it and fits in where I placed the bracket. I also placed the top on so I could confirm the boiler lid pieces have a gap/are not touching, and if I could secure the lid with its screw. However without a plexi it looks a little incomplete...
Name:	marked bracket.jpg
ID:	928820 Click image for larger version
Name:	formed bracket.jpg
ID:	928818 Click image for larger version
Name:	test fit bracket.jpg
ID:	928819 Click image for larger version
Name:	test fit bracket bottom.jpg
ID:	928821 Click image for larger version
Name:	test fit bracket back.jpg
