ECM Technika IV help required
  • ECM Technika IV help required
    I've (electrically) disconnected the water tank of my ECM Technika IV from the rest of the machine to do some maintenance and by mistake deleted the photo I took of the wires position.
    Any chance someone could let me know which wire color goes where, or send a photo of the conmetions. (I've searched the web with no luck)
    Benny someone who has an ECM Im sure will be along sooner or later. I dont have one ...may be that they run a similar wiring loom / layout to Rocket ?
    However your problem is your hanging out for a shot so in the mean time ....
    Try this
    https://coffeesnobs.com.au/forum/equ...treme-machines
    But its only the User Manual. PDF I didnt down load to check.
    OR ring Brisbane based repairer Sugar and Spice Coffee Roasters / Espresso Repairs at Capalaba I believe they are a trusted agent of Charlie at Casa Espresso an ECM retailer / sponsor here.
    Or try new sponsor Eastlink Espresso.
    Or ECA may be the importer and are a sponsor here.
    GL
      benissimmo I believe you are talking about water tank sensor? On the Technika If you've just unplugged the cables from the magnetic reed sensor they can go either way.
      *One end to the board, generally a grey or green cable
      *the other end to the grounding.
      On Rocket the story is similar but you have level probes instead of in-tank magnetic sensors.
      I hope this helps
        What Eastlink Espresso said sounds right. Otherwise, I have a Technika IV and will be opening her up to do some maintenance when some parts arrive in the mail. I can take a photo then if you still need one.
          Thank you all for your input, much appreciated 👍
            Here ya go. Both wires to the reed switch are the same colour on mine.
