Re: Flojet pumps
Just out of interest are you fitting them to the outlet side (best choice) of the pump or the inlet side ( [smiley=evil.gif] side) of the pump?
Reason for the readjustment for others info too is that the pressure loss past the filter ads to the pressure the pump must generate at a given flow rate and this varies slightly with pressure. This also will show as the filter clogs more in lower pressure at the head so change the filters often
Last couple of things on procons or similar if they are a model with an inlet screen fitted make sure it gets degunged once in a while and dont let it run dry or try and prime it for more than 20-30 seconds at a time or the seals will get damaged by the heat generated
.Last couple of things on procons or similar if they are a model with an inlet screen fitted make sure it gets degunged once in a while and dont let it run dry or try and prime it for more than 20-30 seconds at a time or the seals will get damaged by the heat generated
