Re: Flojet pumps
I PMed this to Dave last week but thought I should put it up for anyone who can use it.
Just to remind you, my machine is an Aurora Euopa single group spring lever. No pump needed ( it does have an autofill circuit ) but it needs over 2 bar to refill the boiler and I cant plumb it where I live.
I went to a camping R/V place in Ferntree Gully and bought a 12 Volt caravan pump.
Cost $ 130. Brand Shurflo. Model 2088 422 144.
Went to Bunnings and bought a HPM Garden light transformer # RGLTR60 - 240v ac down to 12v ac. I think $43.
Went to Jaycar and bought a rectifier CAT. NO. ZR1324 and the appropriate capacitor ( to smooth it). Under $10.
The rectifier and capacitor change 12v ac to 12v dc.
Screwed it all on a piece of board so it wouldnt move around.
Connected the 240v ac power from the autofill circuit to the 240v transformer and away it went. i.e. when the autofill circuit decides the machine needs more water it sends 240v to the solenoid and this is where I connected in my outlet to the transformer. So the transformer only gets power when the autofill circuit activates.
There are caveats. Im not an electrician. The transformer is way undersized for the pump but cycles so infrequently that it doesnt even begin to get warm.
The cheapest Flojet I could find was $300 +
John
Flojet pumps
Re: Flojet pumps
Pressurised water systems on caravans, boats, usually consist of:
water in a container at atmospheric pressure.
Hose to a flojet style pump with pressure valve
Hose from pump to a filter
Filter to taps.
When tap is opened, in-line water pressure drops, and a switch on the pump automatically activates the pump until the tap is closed again.
The simple solution here is to go:
Water bottle - pump - filter -coffee machine.
The pumps draw about 7 amps at 12VDC, so sould need a heavy-duty transformer from 240V AC.
Re: Flojet pumps
Hi Sunbeamer,
it is possible to get 240V flojets but they are fairly expensive ($300+) and there is some additional problems with feeding one pump with another, you can fit a pressure regulator but that is more expense and fuss. Best solution is to use the 5 micron filter and pesonally place it after the pump rather than in the suction line and that wil sort it.
Re: Flojet pumps
To answer the original Question, have a look at a large caravan equipment supplier, they will normally have small no name pressure pumps at around the $80 mark, though I am not sure if there are any that will run on 240v, most would be 12v DC
if all you need to do is have a pump to help the water through a filter and be able to lift it some distance (say the bottle is under the bench) then look at car fuel pumps as well, once again 12v but compact and robust
Re: Flojet pumps
as the majority of machines have internal pumps the filter is fitted before the pump(also protects pump)
when we inital setup, we prime the filter and system with mains water supply. this way everything is wet on start up
graham
Re: Flojet pumps
Just out of interest are you fitting them to the outlet side (best choice) of the pump or the inlet side ( [smiley=evil.gif] side) of the pump?
Reason for the readjustment for others info too is that the pressure loss past the filter ads to the pressure the pump must generate at a given flow rate and this varies slightly with pressure. This also will show as the filter clogs more in lower pressure at the head so change the filters often
Last couple of things on procons or similar if they are a model with an inlet screen fitted make sure it gets degunged once in a while and dont let it run dry or try and prime it for more than 20-30 seconds at a time or the seals will get damaged by the heat generated
Re: Flojet pumps
when we set up mobile coffee units we
* install a non return valve near the pump and another at the tank
(generally find these units do not seal 100%, so 2 units gives us more protection
* keep supply line to a minimun length
* 3/8 tubing or braided hose minimun internal size
(under this decreases the flow causing pump vibration)
* 5micron (absolute) water filter (culligan GW)
this is generally the finest filter used, and recomended these days for coffee machines
we used to use .5micron filters for mains connected machines but the cartridges use to block very quickly
(if you visit the Aqualife site you will find the water filter they use for coffee machines is 5 micron (absolute) and .5 micron for drinking water
* on some of the machines which have lazy pumps, we fit a 5 micron (nominal)
* in most instances the pump bypass will need to be readjusted
graham
Re: Flojet pumps
25 years in engineering in heavy industry, mining and petro-chem "bf"... I know pumps dont suck but they (positive displacement types) do evacuate the inlet side of the pump and providing the pump is capable of being primed from a dry state without harm, then they can "self-prime" quite well, even with a filter in the way. As are you, I am also drawing from personal experience, not theory alone....
Re: Flojet pumps
Hi Mal and all,
Repeat after me "Pumps dont suck"
Positive displacement pumps such as sliding vane or impulse piston pums only pump fluid and are limited by atmospheric pressure.
One of the benifits of the Procon vane style of pump is that they move the water constantly and have a low NPSHr (NPSH required) this translates to a greater ability to cope with higher suction lifts etc.
Rubber diaphram (flojet) pumps or UCLA type of pumps will suffer badly when you place restrictions on the inlet side of the pump as the outlet performance will degrade. The rubber diaphram will not deflect as much so you lose volume for a given RPM. In the case of the UCLA the plunger will not move as much (based on there performance curves). In a true piston pump this is not the case as they have rigid valves and pistons so for a given RPM you get a given volume unless you have exceeded the NPSHa (NPSHa).
When NPSHa is less than 0 (normally less than 1-1.5m is considered the safe lower limit) you get cavitation. Cool sound like marble going through the pump but destructive
For a system to work
NPSHa >= Atmospheric pressure (10m) + Water Level (- if under bench) - Vapour Pressure (not that important for cold water) - Pipe and Filter Losses - NPSHr (what the pump needs)
NPSHr is not listed for any of the common pumps used in espresso machines but the procon will be in the order of 2-3m based on similar pumps. The UCLA will be more but it is anyones guess.
Welcome to pumps 101 :
When I was taught this it was nearly a full day so feel free to be confused :-?
15 years in the industrial pump trade BTW
Pumping lots of good and really ugly stuff :P
Re: Flojet pumps
Well actually,
The pumps found in most espresso machines, be they reciprocating or eccentric vane types, are positive displacement pumps and will indeed "suck" through a filter by virtue of evacuating the air in the pipeline. Although, I wouldnt try doing this at both a negative head AND through a filter.... Just asking for trouble for sure. If you had a means of easily bleeding the pump to ensure that the incoming water line from the filter was 100% full of water at all times, this situation would probably remain ok but might require the fitting of a non-return valve upstream of the filter to ensure the water didnt drain out of the line.
Not all pumps are happy to operate in this way of course as some of them rely on water to lubricate the pump seals and without it, will just sit there happily turning the seals into a molten mass. Not very pretty. Procon pumps will certainly be happy to operate this way, within specification but Im not sure what sort of -ve head most Vibe pumps (found in espresso machines) are rated at. No doubt this sort of info could be gleaned from the Ulka or Fluid-o-Tech people.
As you point out though "beanflying", much better to maintain a positive head at the inlet of a pump and avoid all risk; that was why I suggested a simple arrangement to use mains water pressure to supply the prerequisite positive pressure. Still dont believe that a feed pump arrangement is necessary to provide this.
Re: Flojet pumps
NPSH (Net positive suction head) is the reason you cant get any water into the pump past your filter. Below is the simple version.
10m is approx atmospheric pressure or about 14 PSI
Pumps dont suck !!! Atmospheric pressure is the only thing that makes water enter a pump. From this we need to look at the losses from the rest of the system that prevent that from happening.
Pressure losses across the filter are the big problem especially when dirty. A 5 micron filter will drop about 1m but a 0.5 micron wil drop more like 10-15m
Pipe Friction and valve losses need to be considered, also under sink tank (say an extra metre), the pump itself requires some left over as well including a safety margin (2-3m). There is also a correction for temp but it doesnt matter much unless you are getting above 40 C.
So in a basic system with 10-12mm pipe or hose and a 5 micron cartridge it will work but a 0.5 wont.
NPSH is a lot more involved than this but basically the less restrictions on the suction side of a pump the better. The only way to run the 0.5 filter is to fit it to the output side of the pump and maybe a course one on the inlet of around 20-30 micron.
best of luck.
Re: Flojet pumps
I think Dave wants to just set it up and forget about it without having to mess around. Makes sense to me though Mal
Re: Flojet pumps
Hmmm,
Just thinking mate (yeah I know, thats dangerous).... Why not just use the mains pressure to push water through the filter system into the plastic container/water bottle, say from the water spout in the sink or bathroom and then transfer the refilled container/bottle back close to the espresso machine?
Seems like a lot simpler way of doing it and when youve completed a refill, just roll up the hoses for the filter system and put it away in the cupboard. No need for any extra pumps or complication, just a cleverly arranged set of filters and hoses.... 8-)
Re: Flojet pumps
Hey Graham,
Standard 0.5 micron Aqualife water filter. The procon pump will not pump from the water filter, which is why Im looking for solutions.
DS
Re: Flojet pumps
morning Dave
what sort of filtration are you intending to use
what is the minimun pressure required for the filter
in most cases the procon will draw water from a tank through a filter, depending on the micron size of the filtration
graham
