Expobar Unknown (picture inc.)
  • swig
    Re: Expobar Unknown (picture inc.)
    You can perform a few mods to make the machine work a little "better?". Expobar sells the water dispersion bolts, that go under the shower screen, machined down to lift the screens up into the group head. This allows you to fit more coffee into the basket. Up-dosing if this is the way you would like to go. Also finer girculars as I think this machine flows a little fast from memory. It has been awhile since I worked on my machine.
    M.
  • Harlen_Coffee_Kid
    Its a Control 2 GR.
  • DiBort
    HCK,
    Yes, Should be a model number under/behind one of the steam wands. This machine come with 11lt boiler or 6lt boiler. You need to look at the plate.
    Regards
    Renzo
  • yeeza
    9.5L Boiler, 2700w heating Element, Copper boiler. Individual heat exchanger per group.
    Automatic boiler water level control. In built magnetic calcium neutralisers on pump & groups. Pre-infusion chambers on each group. Boiler drain tap. Back up manual fill tap.
    I think this model can come with an inbuilt grinder (on the left besides the groupheads)
  • swig
    I have a similar machine. They are the Elegance model. Check the Expobar website. Should be a model number under/behind one of the steam wands, email Expobar Aust and they will fill you in. Great work horse. Run a little hot. Need to be turned down.
    Martin.
  • Harlen_Coffee_Kid
    started a topic Expobar Unknown (picture inc.)
    Hey All!
    I have no idea on any information on this machine!
    Its an Expobar and i was wondering if anyone knew anything about the specs of this machine!
    Like what are the features whats inside it that is revolutionary or "cool".
    Thanks Guys
    HCK
