ECM Technika V Profi PID - Inconsistent Steam Pressure
  • ECM Technika V Profi PID - Inconsistent Steam Pressure
    Hi all
    I purchased an ECM Technica V Profi w/ PID last week. Great machine however one thing I notice is when I steam milk, the steam pressure seems inconsistent. Sometimes it will drop as low as .6 BAR and remain there until I have finished steaming where as other times it will drop down to .8 BAR then creep back up towards 1 BAR. My understanding from youtube Videos is that it that the later is normal (dropping down to .8 then creeping back up). When it goes down to .6, I find the steam pressure quite low and it takes quite a bit longer to steam milk.
    Can anyone who has experience on this machine provide some guidance here? Is this a fault or is it just how the machine is?
    Regards
    Michael
    Here is a video of it. The machine had been on for an hour and I had not done an espresso shot prior.
    https://youtube.com/shorts/dSkI7PjdYeo?feature=share
      Bump
      Can anyone who owns a ECM Technika help here? I find I almost need to purge for 5 or 6 seconds before I use the steamer nearly every time before I steam milk. If I wait 15 minutes or so after steaming and try again without purging first, the pressure drops to .6 bar and stays around there.
        What temperature do you have the controller set at for Steaming?
          I have a Technika IV w/ pstat. Happy to shoot you a video of the wand purge if you wish, but it may not be very useful to you as mine is not PID. I do get a fair bit of water from a purge, and a reasonably large though momentary pressure drop, if not used recently. Approx from 1.3 down to 0.8 on the first purge, as you said. The manual does recommend a long (5s) purge. Hope that helps!
