1976 La San Marco Tipo 75 two group
  • 1976 La San Marco Tipo 75 two group
    The third and last machine from my most recent shipment is this La San Marco Tipo 75. I intentionally wanted a two group as I like using them in the winter and fall. Perhaps down the road I can fit in an Export version . Initial state looks pretty promising on the outside. As a two group machine it has an additional steam valve and a cup tray valve compared to the 1 group. The only damage I can note is a small dent in the body panels on the top left of the machine when looking from the front. It was already present when I purchased the machine and did not occur during transit. The traffic cone orange panelling really sticks out but it has splotches of random paint on it. I am still debating whether to keep the panels original. The LSM 75 uses the same knobs and portafilters as my earlier LSM 6X machine except for the water inlet knob, which is a button rather than an actual tear drop knob.
Name:	front initial state.jpg
ID:	918882 Click image for larger version
ID:	918881 Click image for larger version
Name:	outside back detail.jpg
ID:	918883 Click image for larger version
Name:	Lion emblem.jpg
ID:	918880 Click image for larger version
Name:	San Marco sign.jpg
ID:	918885 Click image for larger version
Name:	outside corner.jpg
ID:	918886 Click image for larger version
Name:	small damage.jpg
ID:	918889 Click image for larger version
Name:	detail front.jpg
    To take off the panels you need to start in the front and remove the two panels that cover the group heads. Four screws secure the vertical front panel to the frame, while three screws (one was missing) secure the top panel to the front panel. Taking off these panels reveals two styles of groupheads. The left one has some play in the lever fork so I will be inspecting that one closely when I take it apart fully. Both groups have ID numbers stamped on the lower group piece, 9685 for the left and 7187 for the right.
Name:	cup tray off.jpg
Name:	front panels off.jpg
ID:	918891 Click image for larger version
Name:	front group and valves.jpg
      To take off the rear panels a slotted bolt and two phillips screws need to come off on each side. The phillips screws also secure the backsplash to the machine, and the slide it off the hot cup tray valve knob needs to come off too. Once done the back panels come off by pushing the whole assembly forward a bit then lifting it up because there is a lip on the bottom rear of the assembly that slips into the frame for stability.
Name:	panel screws.jpg
ID:	918892 Click image for larger version
      Inside I realized the pstat bracket was in two pieces, leaving the pstat hanging just by its pipe. This machine has an ANCC or similar number, but it does not use the same one as the Lombardy brands (like Faema, Gaggia, etc) because each region of Italy had their own ANCC/equivalent number list. This is why even though the machine is from 3 February 1976 the ANCC number is only 55338 (the San Marco ID tag is 26406) when my similarly aged 1979 Gaggia LL's ANCC number was over a million.
Name:	panels off side.jpg
Name:	panels off back.jpg
ID:	918899 Click image for larger version
Name:	panels off top.jpg
ID:	918900 Click image for larger version
Name:	Boiler numbers.jpg
ID:	918898 Click image for larger version
        The boiler lid came off without too much hassle. I used my little impact driver to get the bolts loose, and nothing was really stuck even though there was a decent amount of surface rust on the bolts. There was old water in the boiler that drained out after taking the lid off.
ID:	918903 Click image for larger version
Name:	old water in boiler.jpg
          The valves and pipes all came off too without issue. The valves themselves differ a little in how the pipe attaches, allowing the pipes to swivel, but the gaskets inside are the same as my LSM 6X and modern machines today. The groups came off after, and I left the group flanges attached to the boiler due to the amount of scale deposits accumulating from the old leaky gaskets. I will descale first before attempting to take those off.
Name:	valve detail.jpg
ID:	918904 Click image for larger version
ID:	918907 Click image for larger version
Name:	boiler and flanges.jpg
            The feet came off, which are the same shape as the LSM 6X. The bolts are horribly rusted so they will likely be replaced. At this point I was satisfied to the progress I made stripping the frame and moved everything into the basement.
ID:	918912 Click image for larger version
ID:	918909 Click image for larger version
Name:	stripped frame.jpg
            Further disassembly will occur soon
Name:	groups and pipes.jpg
ID:	918911 Click image for larger version
              I ran into a really, really bad problem for one of the groups during disassembly. First off I was getting the valves apart along with the other grouphead without issues. The valves allow the pipes to swivel, and are compressed by two conical teflon gaskets and a spring to keep the seal. There was a lot of grease on all the valves.
Name:	swivel valve.jpg
ID:	919045 Click image for larger version
Name:	swivel valve gaskets.jpg
ID:	919047 Click image for larger version
Name:	hole for valve rod.jpg
ID:	919046 Click image for larger version
Name:	greasy valve 1.jpg
ID:	919048 Click image for larger version
Name:	greasy valve.jpg
                One group was fully taken apart. The pistons are the newer style with the big fat v gasket and teflon guide + brass ring. They are still designed to fully relax the spring before the compressing nut comes off the threads of the piston rod.
Name:	disassembling 1st group.jpg
ID:	919052 Click image for larger version
                This is where the real big issue lies. The second group was mounted for disassembly, and I saw the piston rod start turning with the piston. This is not good, and with some inspecting I realized the little pin that prevents this from occuring failed, and I was actually unscrewing the piston rod from the top. This is really bad because there is far less thread for the spring to relax, and the group is not designed to come apart like that with the spring still installed. The piston is more stuck than the upper rod threads which is also an isssue because I cannot access the spring compressing nut that allows me to safely decompress the spring.
Name:	second group piston rod failure.jpg
ID:	919051 Click image for larger version
Name:	second group piston rod failure 1.jpg
                  After speaking with someone who experienced this same issue I decided to try my luck and fully unscrew the rod from the top. I zip tied (these are pretty heavy duty but I will not openly recommend others doing this without understanding the risks and padding themselves in protection) the spring so they would hold back some of the force as the spring relaxed, and it seemed to do a good job as the piston and springs simply fell out without launching themselves when the thread ended. The other person said his piston dented a car in the garage from the force of release. I immediately placed the spring in my decompressor and relaxed it without issue.
Name:	removed spring.jpg
ID:	919058 Click image for larger version
Name:	decompressed spring.jpg
                  Looking at the eye piece there was definitely a little pin that normally secures the piston rod, but it failed/sheared off and left some marks in the process. The piston is really stuck on the rod and I have not been able to get it loose yet. I will need to work on that more but I am just happy I was able to get the group mostly apart and not potentially need to replace an entire upper housing.
ID:	919059 Click image for larger version
Name:	piston eye detail.jpg
                    __________
Name:	piston rod threads.jpg
ID:	919062 Click image for larger version
Name:	stuck piston.jpg
ID:	919061 Click image for larger version
Name:	stuck piston detail.jpg
ID:	919064 Click image for larger version
Name:	mostly disassembled groups.jpg
                      I managed to unscrew the piston finally. Both the piston and the spring compression nut were tightened way too much. I had to strike my spanner wrench with a hammer to unfreeze the threads, and before that I also did a few heating and quench cycles. I also had to tilt my spanner at an angle because the notches on the face of the piston are not cut parallel to the face, but rather at an angle. I also fished out the broken pin from the top. Seeing how tight the piston was screwed in I am not super surprised it snapped, but hopefully I can clean up the piston bore and related parts without issue. The random chrome flakes are from the piston bore, and it crumbled out in pieces during disassembly.
ID:	919074 Click image for larger version
ID:	919072 Click image for larger version
                        I figured out why there was some play in one of the groups (the older looking one that was originally on the left), and that is because the piston rod is loose, and the internal pin was failing. It was taken out in two pieces. I also had to clean the threads from the metal glitter that was created from the pin that completely failed.
Name:	borken 2nd pin.jpg
                        In the meanwhile I did my degreasing and cleaning regime for the valves and relevant group parts. I had to do multiple rounds in the tumbler due to the large number of parts I was cleaning. Some parts are plated so they will not give as much shine. There's various other parts in the mix like the group and flange nuts, a few body panel screws, the heating element nuts, etc.
Name:	degreasing parts.jpg
ID:	919229 Click image for larger version
Name:	tumbler parts.jpg
ID:	919228 Click image for larger version
Name:	cleaned LSM 75 parts.jpg
                        The manometer actually has a more recent date than the machine, 5 July 1977. I wonder if the original one failed. The bezel was also missing one of two tiny screws that secure the bezel to the manometer.
Name:	5 July 1977.jpg
                          I investigated the frame a little more too because I have seen on other San Marco machines the group/flange studs are not metric. Looking into it the studs are actually just a regular M8 x 1.25 thread, and I was easily able to thread a bolt onto an original nut and thread an M8 nut onto an original stud. The studs screw into the frame and can come out, and I got them all taken off this week. I measured on my LSM 6X and that one does have an SAE thread for the group studs, 5/16" 18 TPI
Name:	taking of frame stud.jpg
                          The lower skirt pieces come off via six screws, two on each front corner and one on each rear corner. The skirt is made of two pieces, one covering the front and sides and the other piece covers the rear and also secures the little foot frame pieces. The two 'feet' pieces I am referring to simply slip on over two beams at the bottom of the frame, and are only secured by the four aluminum feet I took off earlier. However, there was some rust from the frame that fought me while slipping the pieces off.
Name:	rear screw lower skirt.jpg
ID:	920269 Click image for larger version
Name:	front screws lower skirt.jpg
ID:	920270 Click image for larger version
Name:	front skirt off.jpg
ID:	920272 Click image for larger version
Name:	foot frame off.jpg
                            I had to wait for the arrival of a big (and I mean BIG) 35mm wrench to take off the dipper tubes. The design of the boiler did not allow me to fit my adjustable wrench and be able to exert enough torque to loosening the big 3/4" BSP dipper tube threads. With the 35mm wrench I could easily fit the tool and knock both tubes loose with my deadblow hammer. I am able to lock the outer fitting onto my vise which allowed me to exert the necessary force. The dipper tubes are designed differently from the modern San Marco dipper, with female threads for the old one instead of a male thread for the modern tubes. You can also see the LSM 75 tubes are a little longer than the LSM 6X, shown on the left.
Name:	unscrewing dipper tubes.jpg
ID:	920278 Click image for larger version
Name:	dipper nut on vise.jpg
ID:	920274 Click image for larger version
Name:	dipper tubes off.jpg
ID:	920276 Click image for larger version
Name:	compare to LSM 6X.jpg
                            With all the pieces apart I spent most of today cleaning them and taking off the nasty old gaskets. I had to take picks and gently poke off the gasket residue, and with some wire wheeling, citric acid baths, and magnetic tumbler they are all cleaned up.
Name:	tumbler in use.jpg
Name:	scraping old gasket.jpg
ID:	920281 Click image for larger version
Name:	cleaned dipper and flanges.jpg
                              The boiler is cleaned up to my satisfaction. A nasty gasket was taken out of the boiler lid and I am still cleaning that up.
Name:	cleaned lsm 75 boiler.jpg
ID:	920283 Click image for larger version
Name:	yummy gasket.jpg
