1976 La San Marco Tipo 75 two group
  • #16
    I took apart the original pstat. Unfortunately this older style of sirai does not have available spares from the big parts sellers, but it is certainly a cool piece. It is designed just like modern Sirais but with the diffrent membrane. I will be using a modern Sirai 20A for now but I will see if in the future I can get a spare membrane kit made for the original.
ID:	924774 Click image for larger version
Name:	bottom sirai with membrane.jpg
ID:	924771 Click image for larger version
Name:	top membrane holder.jpg
ID:	924773 Click image for larger version
Name:	sirai membrane off.jpg
ID:	924772 Click image for larger version
Name:	sirai apart full.jpg
    • #17
      The hot cup tray valve was taken apart after my metal guy showed me you can clamp a socket in the vise to exert the leverage needed. Nifty stuff. It's the same design in terms of seals used in modern San Marco machines.
      Click image for larger version  Name:	unscrewing cup valve.jpg Views:	0 Size:	207.7 ** ID:	924777 Click image for larger version  Name:	cup valve apart.jpg Views:	0 Size:	194.6 ** ID:	924780
      The body panels were washed up. I will keep them original, but I did need to bend back one of the side brackets and panels that appears to have been struck by something in the past. I used my vise to get the worst of it out. I also got rid of the crud on the lower panels using green scotch brite to pretty good effect. The feet are still at my metal guy's place since they are getting media blasted.
      Click image for larger version  Name:	top panels off.jpg Views:	0 Size:	224.9 ** ID:	924779 Click image for larger version  Name:	upper panels.jpg Views:	0 Size:	261.9 ** ID:	924778 Click image for larger version  Name:	bending back panel.jpg Views:	0 Size:	236.5 ** ID:	924781
      • #18
Name:	cleaned lower panel.jpg
        The boiler and pipes were cleaned up on the wire wheel. The hot water pipe fitting will need some extra sealant tape, or perhaps even a repair as it wobbles a bit.
Name:	wire wheeled boiler and pipes.jpg
ID:	924786 Click image for larger version
Name:	wire wheeled boiler .jpg
ID:	924785 Click image for larger version
Name:	damaged hot water pipe threads.jpg
        • #19
          I got my frame back from my Metal guy. It was powdercoated a black with 80% gloss, really shiny and nice looking. I also had him clean up the lower stainless steel panels that slip on the bottom of the frame, the boiler lid, and the corroded feet. The o ring I am trying out fit extremelly well, and it is a perfect snug fit inside. I am really optimistic it will work with this boiler lid style. Please don't mind the Marte missing its body panels in the back, that is how I found it best to move it without assistance.
          Click image for larger version  Name:	20220819_174805.jpg Views:	0 Size:	299.1 ** ID:	925419 Click image for larger version  Name:	o ring in boiler lid .jpg Views:	0 Size:	183.9 ** ID:	925415
          I assembled the two groups when I received my Eevad order containing the last parts needed to begin. I first started with the lower groups and installed the preinfusion valve + one way valve. The former is a little difficult to install due to the strong springs necessary to keep water from escaping from the boiler when pressurized. I had to push down while turning the threads to get them to engage. The one way valve was easy enough to install, and they tightened perfectly in the correct position.
Name:	San Marco group parts1.jpg
ID:	925444 Click image for larger version  Name:	group inlet assembled.jpg Views:	0 Size:	275.1 ** ID:	925418 Click image for larger version  Name:	upper group inlet .jpg Views:	0 Size:	210.2 ** ID:	925417
          • #20
Name:	one way valves on.jpg
            The upper group starts with the lever fork and rod assembly. I was able to reuse the original bearings after cleaning and regreasing them. The roller pins will stick to the bushing when the tacky grease is applied. There is a lever fork pin that is pressed through the bushing and pins. My ball bearings were made in the USSR, and this is not the first time I've seen that on espresso machines.
Name:	fork eye bearings and rod.jpg
ID:	925423 Click image for larger version
Name:	USSR bearings.jpg
ID:	925424 Click image for larger version
Name:	roller pins tacked to bushing.jpg
ID:	925421 Click image for larger version
Name:	inserting fork pin.jpg
            • #21
              Click image for larger version  Name:	pressed pin.jpg Views:	0 Size:	165.1 ** ID:	925427
              The felt washer is stuffed in a recess in the upper group housing and the piston rod can be inserted then secured with the bearing bolts. The springs can be installed after, and I had to compress the big spring about 13mm to allow the spring nut to thread on. At this point the upper group is inserted without the piston into the lower group because the fat piston v gasket flares out too much to be inserted from above. Thus it needed to be screwed in below, and is why I decided to just buy the tool for future maintenance. I was able to hand tighten the pistons enough they are when the groups are standing upright for the short term.
              Click image for larger version  Name:	felt washer and bearing nuts.jpg Views:	0 Size:	195.1 ** ID:	925430 Click image for larger version  Name:	aligning bearing hole.jpg Views:	0 Size:	298.0 ** ID:	925431 Click image for larger version  Name:	Screwing spring nut.jpg Views:	0 Size:	206.2 ** ID:	925428 Click image for larger version  Name:	compressed spring.jpg Views:	0 Size:	189.3 ** ID:	925429
              • #22
                __________
Name:	piston on group.jpg
ID:	925436 Click image for larger version
Name:	piston seal too fat.jpg
ID:	925435 Click image for larger version
Name:	upper group in lower group no piston.jpg
ID:	925434 Click image for larger version
Name:	piston assembly.jpg
ID:	925433 Click image for larger version
Name:	partially screwed piston.jpg
                • #23
                  With that they are both assembled minus the portafilter gasket and showerscreen. The preinfusion lever had the roller pins replaced but they are otherwise in good shape. There is a tiny bit of play with the left group due to wear but it should not impede function. I did however need to use loctite instead of a rod pin for the same group because it screws tighter than the pin hole can align properly.
Name:	preinfusion valve.jpg
ID:	925439 Click image for larger version
Name:	assembled groups.jpg
ID:	925440 Click image for larger version
Name:	assembled groups back.jpg
                  • #24
                    This is about 2 months worth of updates going on here.
                    After the groups were assembled I focused on cleaning up the little feet. They were severely corroded, so the first thing I did was media blast them. I then used a folded piece of 240 grit sanding belt attached to a jacob's chuck adapted for my little omega grinder to get rid of as much pitting without compromosing the integrity of the foot. I hand sanded dry to 800 grit then up to 5000 mesh grit wet (320 600 800 1000 1500 2000 3000 5000 grits were used). I am posting the original condition of the feet again because I was quite happy with the results.
Name:	paper sander thing.jpg
ID:	930748 Click image for larger version
ID:	930749 Click image for larger version
Name:	polish sanded media blasted foot.jpg
ID:	930745 Click image for larger version
ID:	930746 Click image for larger version
Name:	polished feet detail.jpg
                    • #25
                      I replaced the rubber feet that were all basically disintegrated with new ones I sourced from rubberfeet.us Large Round Rubber Feet - .500 H x 1.312 inches. It cost me $7 with shipping and removing the metal bushing allows me to fit the M6 thread that secures the foot to the frame perfectly. I made sure there was clearance so the hex head was not touching the surface the machine rests on.
Name:	new feet and removed bushing.jpg
ID:	930752 Click image for larger version
Name:	foot with new rubber sole.jpg
ID:	930753 Click image for larger version
Name:	rubber foot bottom.jpg
ID:	930755 Click image for larger version
Name:	new feet bolts.jpg
ID:	930754 Click image for larger version
                      • #26
                        I mounted the groups afterwards. I used new stainless setup studs to replace the old ones since they were slightly damaged in the thread (pre removal). I needed to make sure the one way valve was not interfering with the flange, which will happen if not tightened to a correct orientation. I did receive the piston tool so the pistons are tightened properly. When pulling the levers down they are so strong that the frame tilts without the boiler. However I hear rubbing of the spring and bore on the left group so I'll need to adjust that later.
Name:	stud comparison.jpg
ID:	930761 Click image for larger version
Name:	O ring for group detail.jpg
ID:	930757 Click image for larger version
Name:	aligning one way valve nut.jpg
ID:	930759 Click image for larger version
Name:	group mount detail.jpg
ID:	930758 Click image for larger version
Name:	rear groups mounted.jpg
                        • #27
                          The bakelite handles were cleaned up and polished. They were lightly sanded then polished on my Baldor buffer with white tripoli. I learned a trick to use a screwdriver to hold the round piece against the wheel so one spot is not focused on during polishing (also useful for sanding which I did with the feet).
Name:	bakelite and pf pre clean.jpg
ID:	930764 Click image for larger version
Name:	yummy coffee water.jpg
ID:	930763 Click image for larger version
Name:	bakelite sanded.jpg
ID:	930765 Click image for larger version
Name:	screwdriver bakelite polish method.jpg
ID:	930767 Click image for larger version
Name:	polished bakelite.jpg
                          • #28
                            The valves were assembled this week. The steam taps and hot water tap are the same design, but I had to replace one of the fittings due to cracks in the old one. The replacement has a 1/4" BSP thread so I will need to braze a new pipe for that. I also assembled the water inlet valve, but I will need to test if it can hold pressure since the modern inlets have a slightly different design. I am using a steam tap teflon conical gasket (which is what the modern ones use) and a 7x3mm o ring.
Name:	valve fitting comparison.jpg
ID:	930769 Click image for larger version
Name:	san marco valve.jpg
ID:	930770 Click image for larger version
Name:	assembled valves.jpg
ID:	930772 Click image for larger version
Name:	LSM 75 water inlet.jpg
                            • #29
                              The cup warmer valve came together too. And this is the current state of the machine. I was waiting for 240V to be installed which happened today, so I can proceed forward with my two San Marco machines. The breaker is 20A 240V with GFCI, plently for my needs.
Name:	valves on frame.jpg
ID:	930775 Click image for larger version
Name:	cup valve .jpg
ID:	930777 Click image for larger version
Name:	cup valve detail.jpg
ID:	930776 Click image for larger version
Name:	assembled cup valve.jpg
Name:	240v junction box.jpg
                              • #30
                                The boiler was mounted with teflon tape and copper crush washers. I'll soon find out if I tightened the big two nuts enough connecting the boiler to the group flanges.
ID:	932513 Click image for larger version
Name:	mounted boiler.jpg
                                The heating elements were attached after to the cleaned boiler lid. The terminals and screws were also cleaned but separately in the tumbler. New M10 bolts were installed once the pstat bracket was made.
ID:	932509 Click image for larger version
Name:	lid mounted.jpg
ID:	932510 Click image for larger version
Name:	cleaned element terminals.jpg
