Synchronika not drawing water
  • Synchronika not drawing water
    Tried to make a coffee with my Synchronika this morning, and no water came out of the group. The pump sounds like it's working, but it's just not getting any water through. Confirmed the steam boiler is also affected, and then turned it all off to protect the elements. It's a real pain to get it to the shop, is there anything I should look at before I do that. I feel like there could be a blockage in the path between the water tank and the pump, though I don't see what ... I only use filtered water and if there was a scale problem, I'd expect to find that in the mushroom or something not before the pump. Or the pump is broken, although it doesn't sound obviously different to me. Does anyone else have any ideas?
    Ok, please ignore. Suddenly had a thought that maybe I had switched it to plumbed mode in somehow, and looks like that's exactly what happened ?‍♂️
    • Berigora
      Berigora commented
      Editing a comment
      Or how many times has this happened to me when the reservoir empty
