Eagle One Prima owners
  • Eagle One Prima owners
    Hi current owners or people with experience with this machine,
    I’ve been lurker on the forum for some time dreaming about what machine to get.
    I’m looking into the E1 Prima - now more than a year on in the market would you still recommend this machine?
    Are there any issues (other than water tank / drip tray) I should consider?
    What grinder have you paired with it or unit you are thinking of moving to?
    Would really appreciate your thoughts.
    I have had the machine for 7 months. It is a fantastic machine, I use it with a Niche Zero grinder. The combo works perfectly.
    However, there has been issues (mostly with old firmware) where the memory battery would die way too quickly. Seems to be fixed with current 2.3firmware.
    Also many users had an issue with the steam boiler's thermofuse being too sensitive. It hapenned to me once. I now have a spare one (same for the battery) just in case.
    you can find many informations and feedbacks on the Facebook group page
    I hope this helps.
    Nico
    • TDK
      TDK commented
      Editing a comment
      Thanks for the Facebook group link. Looks like some people are also having steam boiler leaks. I will also read up on the R91 and see whether I should spend the extra $3k for the pressure profiling.
    Have you loiked up prev threads on CS regarding both machines you mention?
    Search function above....
    GL
      Thanks EA,
      I think I have found and read most of the posts re R19 on here.
        And the EagleOne Prima ?
        iirc possibly 2...
