Aeropress Users...
  • Aeropress Users...
    Lend me your ears! ;D
    Sorry, that was in my head for some reason and I had to get it out.
    But seriously...
    Just a quick question for those of you using these seemingly great pieces of coffee making gear. And its in relation to clean up.
    How little water would you or could you use to clean up an Aeropress?
    I ask because a few fellow campers are commenting on how most of our coffee making equipment requires a bit of water to clean up and when youre camping, you dont always have the luxury of lots of available water. So, the question was asked if the Aeropress could be cleaned with little water.
    Scoota
    Re: Aeropress Users...
    Can be cleaned with virtually no water - the head of the press cleans the cylinder as you press (like a syringe), you can then pop out the puck and wipe off the end of the head with a paper towel. The only water you may use is to rinse the paper filter so you can use it again.
    Sniff
      Hiya Scoota
      My Aeropress has been getting a workout since the Sunbeam died on the weekend....
      I have found rightly (or wrongly) you can probably get away with as much or as little water as need be to clean it. I usually give mine a quick rinse and wipe between repeated use and a good wash once Ive finished using it, but in each case it uses signficantly less water than the typical plunger. The filters are disposable, coffee pucks are amazingly solid and the rubber seal does a good job of cleaning the inside of the Aeropress tube, so that saves a bit of water too on cleanup (i.e. you could probably get away with a quick wipe and a damp towel if you were camping)
      Ill do a test run in the morning and post how many mls of water I use to clean it and let you know.
        Agree with these Guys,
        If camping I would take extra filters (and dont bother reusing like I normally do) and as Sniff says, wipe the end of the piston with a tissue/paper towel. ie. no water at all.
        Of course youll still need about 60ml of water to make some coffee...
        Yxoc
          Thanks folks! I really appreciate your answers.
          Yxoc, thankfully, 60ml is not a whole lot!
            Scoota, what kind of grinder are you using while camping? Or are you packing the grinder away and using an inverter? ;D
              Switched...Im using a Kyocera hand grinder now. Its a great bit of gear. Mind you, I did check the power usage of the Rocky to see if I couldnt take it with me! But, a big inverter sucks a lot of power, something I dont have a lot of with a 105amp/hr battery and 100watt solar panels. Though, if I was only camping at powered sites, all of the manual process coffee making would be out the door...er tent... ;D
                Yeah I agree with the others,
                when camping I only use filter once and throw it in rubbish bag,
                press the puck into rubbish bag and quick wipe of the press, then wash at end of day with rest of dishes, etc, so no extra water really required.
                Having said that, the comments that the press self cleans is I think a bit hopeful, as I can usually see a line of coffee coloured something around the inside of the barrel, so i prefer the concept of relatively self cleaning. I think they benefit from a proper wash say once a week or so, but certainly they are much better for camping/travelling/at work than some other ways of making coffee.
                  Agree with all your comments Bullitt. Gave mine a quick wash and it came to about 100-150mls of water all up and that was probably being a bit liberal as I was using the kitchen tap and a damp wash cloth
                    I use my Aeropress at Uni, where I have no access to paper towel or a cloth.
                    And it is more then easily cleaned with just the tap.
                      The piston and cylinder dont really need washing at all. The piston wipes the cylinder perfectly clean and you can wipe any bits of ground coffee off the end of the piston with ease. If you discard the filter you dont need to wash that.
                      That just leaves the black filter holder which really should be washed of coffee oils, but I reckon you could get away with 10ml if you had a dish just a little larger than the filter holder itself.
                      Bottom line is, next to nothing. Ive used my Aeropress and Hario combo on picnic trips and have no complaints.
                        Im a little shocked to find that some people here use the filters more than once, and am interested to find the reason - can a re-user please let me know their thoughts on this?
                          Erm, well, they wash really well and it seems just a little bit wasteful to throw them away after one?  :-?
                          The Aeropress instructions also suggest it....quote:
                          "Two thousand filters use about as much paper as one city newspaper, so you neednt feel guilty about discarding filters.  But you can also re-use each filter many times just by brushing it off under running water.
                          The choice is up to you"  ;D
                          Sniff
                            Originally posted by 75594C4C505D4F677D4A515B380 link=1278925660/11#11 date=1280068678
                            Why shocked?
                            As SniffCoffee has pointed out, the instructions mention that you can.
                            At first I didnt believe you could wash a paper filter so tried it and they are surprisingly tough.
                            Secondly, Ive always been a recycler/reuser so it was a plus for me.
                            At home they get used a few times each, until they get a bit too wrinkled to sit flat (probably my heavy handedness in washing).
                            If I was using it while away Id probably just bin them.
                              Heya,
                              I guess my shock was thinking that itd spoil the taste a little, a little like re-using cigarette filters.
                              Im a renew - reuse - recycle kind of guy as well and was pretty happy with them going into the compost... I might have to try squeezing a bit more life out of them. As soon as I finished laughing at the cheesy packaging it all went in the (recycling   ) bin, I must have missed the reuse part of the instructions.
                              Thanks for the info
