Ive been experimenting with making cold drip with my Aeropress since seeing a tweet regarding the same by AndreasM.
Im only up to my second batch but the idea seems to work easily and it seems a cheap way to try it out without having to go to the expense of a ready made system.
Heres what Ive done so far with input from various people:
*Use 2 filter papers instead of one in the filter holder.
*Grind 50g (courser than espresso) and put into Aeropress.
*Use a lighter roast (filter not espresso) (Im still experimenting with my espresso beans - will buy something lighter soon).
*Put another filter paper on top of the ground coffee (folding the paper into eighths then trim about 2mm - then crease in alternate directions to help it fit flat into the chamber - the top filter paper helps spread the water across the top of the coffee - without it I got a neat little dent in the middle of the coffee and was worried it wasnt going to extract evenly).
*Use 500ml of cold water (the bottle in the picture is 600ml - its what I had handy).
*You need a small hole in the bottom of the bottle to let in air (I tried without the hole and it will soon stop dripping).
*I modified my first attempt by installing a garden dripper into the lid (see picture (excuse phone quality pic) - purchased from Bunnings).
I got 345ml out of last nights batch.
I thought I got a little more from the first one but didnt measure it exactly.
The grounds will hold at least 100ml of the water it seems.
I thought it would be good to keep the water cold as it dripped so I moved a shelf down in my beer fridge for some extra height and once Id put everything together and adjusted the flow rate, I sat the whole thing in the fridge to do its thing.
The dripper is a bit fiddly to adjust as its meant to run off hose pressure, but with a little fiddling you can set it between notches and get about a 1 to 1.5 sec drip rate.
My next change will be to the hole in the bottle to see if a larger hole will help make the adjustment at the dripper end less finicky.
The picture shows the bottle sitting in the Aeropress and a closeup of the threaded dripper. You can see the top filter paper sitting on the coffee.
