Silex vacuum coffee brewer spare parts
  • Silex vacuum coffee brewer spare parts
    Does anyone know if replacement seals are available for the Silex Vacuum coffee brewers ? There was a narrow neck version and a wide neck version. I am looking for a wide neck seal. Any leads on where to source? Possibly early 1950s or earlier. Similar to photos attached
    Re: Silex vacuum coffee brewer spare parts
    I am fairly sure there is a US company making them as an after market part. Bad news Narrow neck ones available but not the wide neck.
    Wide-neck Replacement Rubber Gaskets
    Food Service Direct once sold replacement gaskets for a stainless steel vacuum pot in the style of the vintage Cory/Nicro pot. I have received reports that these gaskets work well on some older, wide-neck pots.
    Note: Food Service Direct no longer sells the replacement gasket for the Adcraft vacuum coffee pot (AdCraft has apprently discontinued this item), but they still have some of the replacement filter assemblies in stock. Get em while they last!
      Thanks for the feedback. I have seen narrow neck ones on US based web pages but not the wide neck versions.
        I was also trying to find a thread on a US site about refurbishing the seals by soaking them in a petroleum based solution (not sure which one). While a bit nasty the theory is that it softened the rubber again.
        The other option you have is to try and buy a section of soft rubber extrusion that is close and glue one up. Look up "Tulip seals and packings" or "Mackay Rubber" for a start maybe. If you do any good with a section and want to split some drop me a PM as my Silex is a bit harder than ideal.
          I will go searching again. Part of the problem on the Silex I have is that the rubber is so hard removing it will destroy the seal completely. I am not sure how easy it will come away from the glass. I am not prepared to try untilI have a replacement seal.
            We used to use a product called "Xylol" (Xylene) for this purpose but I dont know if it is still available over the counter anywhere. Its very nasty stuff, as you pointed out....
            MSDS here... http://www.jtbaker.com/msds/englishhtml/x2000.htm
              From the above site Xylene looks very nasty.
              In the dairy industry caustic soda (Sodium Hydroxide) is used at a 5% solution for cleaning the rubber on milking machines. The rubber can be soaked in it. Natural rubber is highly resistant to the caustic so is used for lining vessels in contact with caustic solutions.
              It is extremely alkaline and must be used with care not to get it on skin or in eyes.
              Dairy chemicals are available from farmer suppliers or friendly dairy farmers.
              Less toxic is soda ash and washing soda (Sodium Carbonate). Soda ash is 3 to 4 times as concentrated as washing soda and is available from swimming pool suppliers or friendly swimming pool managers.
              Barry
                Thanks for ongoing feedback
                  Originally posted by 0B26222E234F0 link=1284705004/5#5 date=1284818212
                  Xylol
                  That sounds like the stuff :P Also keep an eye out on evilbay USA as chamber that get broken still have seals :
                    I cut a new "gasket" from an old inner tube in an attempt to improve the "airtightness" or seal on my wide neck Silex, it worked well.
                    Way back at the end of June Flynn Aus  found a product with unlimited uses, perhaps it could solve your problem.
                    Originally posted by 2E24312626293D3B480 link=1277785626/0#0 date=
                    Mouldable silicon putty
                    29. Jun 2010 at 14:27  Im sure someone will find this useful:
                    Sugru mouldable silicon
                    If you’ve ever wanted to mould a plastic just perfectly for the project at hand, Sugru offers a unique product for the DIYer’s toolbox — mouldable and self-curing silicone putty. Sugru comes in a variety of colours and sizes. Six 5g packets in single colour will run you $US9.
                    Goggle search Sugru & watch the amazing video clip!
                    David
                      Ahoy! Beanz, did you ever solve your gasket problem?  Ever find a source for new wide-mouth gaskets?  Ive been searching on and off for a couple of years with no luck.  My gasket isnt hardened--its nice and supple--but it doesnt make a good seal on the bottom globe.  Ive tried all kinds of things to fix it--silicone, rubber cement, vinyl putty, nasty rubber patching goo-- but nothing works (fortunately it all comes back off, as well!), and I want to replace it, if I can find a good replacement.  Ill check out the suggestions made in this thread, but what I really want is a NOS gasket or a good silicone copy.  Any ideas?
                      Thanks for any help.
                      Jim Crutchfield
                      Long Island City, New York, USA
                        Hi Jim
                        I have not found a source yet but I am sure something will pop up one day. I have left it in its original condition and do not use it at this stage. I use a current model Hario for Syphon coffees. I would like to do a full restoration if the appropriate replacement part could be sourced
