New cold brew - Cold Bruer on kickstarter
  • tropellor
    Has anyone tried an able disk with their Bruer instead of the paper filter? I'm thinking I might do a comparison.
  • bytheway
    Originally posted by dans1982 View Post
    A good little conical burr grinder for filter coffee is the Baratza encore, $175 brand new. Light weight and grinds straight into a container so you can switch it on and walk away till its done. I've been using mine for a little while now and it works a treat. Not good for espresso though, purely for filter or cold drip. The grinder on the right obviously.
    [ATTACH=CONFIG]8072[/ATTACH]
    How does the Baratza compare to the big Mazzer (is that a Kony, SJ or Robur?) I've got a Kony E but not happy with it for filter...also wondering about getting a Feldgrind or Hausgrind or Lido II/III
  • jaredw
    Originally posted by artman View Post
    Have done a couple of brews in the bruer and it is a nice but of kit. The large glass pieces make handling and washing it a careful process, I am weary of breaking the glass.
    Does make a nice brew and is great to use.
    Regards
    Arthur
    What is your extraction time?
  • dans1982
    Originally posted by gonzo89 View Post
    I just purchased a Smart Grinder Pro for pourovers and i must say for its price it performs very well. I love the functions it has. Although I still prefer my Eureka for espresso, but its not bad at that either.
  • tropellor
    Hey Everyone,
    I'm getting a 7-8 hour extract, and it's coming out a little bitter. What are your thoughts on getting it sweeter. I'm assuming it's the grind, but not sure if I should go finer or coarser.
    It was funded last November I believe. You can already purchase them.
    Sure can: Bruer Cold brew system | Talk Coffee
  • artman
    Regards
    Arthur
  • gonzo89
    Originally posted by Al View Post
    This is my first kick starter, does anyone know if making it available before the end of the kick starter is acceptable to them?
  • gonzo89
    Preiam I was going through the same decisions when I was looking for a new grinder and I ended up buying a Breville Smart Grinder. I have not regretted it at all, check the thread in the grinder section for way more info.
  • gonzo89
    Originally posted by jbrewster View Post
    At this price point it's pretty much unbeatable.
    It sure is beatable check out the Australian invention Brewover on Kickstarter that is currently running. There is another thread about it if you want to know more. This has the functions of the Bruer but with a large cone for pourovers and a solid valve. Several CS' ers including myself have pledged for it already. Very affordable
  • Al
  • Al
    Jbrewster how much did you pay?
    (Edit, removed the bit from the wrong thread)
  • preiam
    hey guys - this is my first comment on the forum (so be nice). I'm thinking of getting a bruer to make some cold brew and would like to get a pretty decent grinder for the job. I'd also like it to do a good espresso grind in case i make the investment to getting an espresso machine. My current preference is a vario doserless. I would appreciate any advice! Cheers
  • jbrewster
    Apparently it's now generally available, picked mine up yesterday.
    Does what it says on the box First batch was pretty successful but I need to tweak my grind a bit, the valve is a novel design but a bit twitchy.
  • rustla
    Originally posted by jaredw View Post
    Had a similar train of thought. Good to hear it's not just mine. Would love to know if anyone has managed a brew time of above 10 hours.
    I got mine to 12 hours over the weekend.
    I've been using no ice to make it easier to monitor, at room temp.
    Checked the drip rate every few hours and ended up speeding up for the last hour so I could put the finished product in the fridge before going to bed.
    Probably could have stretched it to 15 hours.
    First time I've ever been able to do that though.
