Why the apparent Australian preference for table top vacuum brewers and messing with butane or spirits burners for heating? I realize Hario only does such vacuum brewers but both Bodum and Yama do stove top vacuum brewer versions. To me the stove top units are a lot easier to deal with unless you want a small unit which only brews 120 to 360 ml at a time. I use a vacuum insulated travel mug for my coffee and it holds about 600 ml so I want a sizable brewer. The smallest vacuum coffee maker I use is a 660 ml or so Yama. The largest is a 12 cups Nicro that holds over 3 Imperial pints of water when filled.
To me the old Cona table top units and the Hario and Yama clones look like something assembled by a chemistry laboratory assistant who was desperate for a cup of coffee and used available lab glass to put together a vacuum coffee maker. In fact it is the almost identical look to some of the earliest vacuum coffee makers the French produced as early as the 1840s or so per photos in the Bramah book on the history of coffee makers.
