Tiamo Cold Drip HG2669 - Help
  • Tiamo Cold Drip HG2669 - Help
    Hi Guys,
    I just bought a tiamo Cold Drip HG2669 online and maybe I'm missing something but it seems to be missing the filter?
    I was hoping that someone could potentially advise on what's missing and where I may acquire the missing components.
    Thanks in advance
    I believe they use paper filters like these in BeanBay.
    Java "Check for proper sizing" phile
    Toys! I must have new toys!!!
      Thanks Javaphile,
      I will pick up some of those for sure but the thing I noticed that's different were the ones I saw for sale had a section at the top near the taps with a red plug mine doesn't have this it's just a tube:
        Ah, that must be a newer feature. On the older designs it was just the paper filter as seen in this video at 1:41.
        Java "New device, same job...any difference?" phile
          Kinda seems like the coffee would just fall down the hole and into the serving flask if I just put the paper filter on top like in the video.
          I guess I can give it a go and report back...
            If you have the part in your picture I suspect you don't need the paper filter. The part in your picture replaced the paper filter.
            Java "One or the other" phile
              Yama cold drip has a "ceramic stone" in the bottom under the coffee and the paper filter used on top is more about stopping the splash and drilling a hole into the top of the grounds.
              Maybe you are missing the two ceramic/sandstone discs? (or you can just use a paper filter in the bottom too if you "load" it carefully I guess)
              Site Sponsors Alternative Brewing and Coffeeparts both sell them and other site sponsors probably do too.
