Hello fellow snobbs, I just recently dug up my old Imat Mokita Combi (manufacture in 2003) from storage. Upon giving it a wipedown and putting some beans in the hopper, priming the pump and started to brew, I found that the grouphead was leaking when I was brewing, I have subsequently dismantled the grouphead and found that the rubber seal is qute perished. Attempted to get the showerscreen nut off, but it was stuck. It was slightly bigger than a 13mm and smaller than a 14mm. I had a closer inspection of the machine and found that all the s/s panels were riveted. I would really like to "overhaul" this machine as I remember it to be a semi decent machine. I was just wondering if any of you would know:
1: where I can get an exploded diagram of various parts of the machine
2: do I have to drill out the rivets to get to the boiler, etc..
3: where can I source parts for this machine especially the seals, etc..
4: are there any snags to dismantling it and what parts usually need replacement
5: any of you come across a stuck bolt and how to free it????
I hope some of you experts out there can shine a light on this subject
Thanks in advance
Thanks in advance
will i be able to get this to work without too much effort?
