Originally posted by 4543515F5A4358360 link=1232674232/4#4 date=1233197841
From what I can see it will be a bit of a fiddle... I know the local guys here have found a way, to short cut some of it.. VS the procedure / manner set out by SB.
However, the one thing I do know, is that you need to ensure you get spare screws as depending on which batch you will STRIP the heads off.
I will try to get a pic or two of the TOP (All exposed) and you may be able to GUESS as to what can be done..
Not sure if it all has to come out... OR it is access to the screws that causes the problem...
PS. What is teh $$ you have been quoted to do the Job and what is the cost of teh collar ?
Excuse the mess, was working on other items and had to quickly make room... Yes that is a k series phone.. Surface mount components and OLD men do not mix. Got 2 fixed and messed up on the third.. Any one want some spare parts / screen / ** etc...
