Can I get something decent for $600?
  • Can I get something decent for $600?
    Im new to this site. what an amazing site.
    Im looking at getting a new machine.
    I have the Breville Roma at the moment, pretty dodgy little thing.
    but ready to get something more decent.
    Would $600 be able to get me some decent, and Ill need grinder as well.
    Should I be looking for some second Silvias or something.
    Any help greatly appreciated.
    Thanks all
    Re: Can I get something decent for $600?
    What coffee style is your favourite
    If its espresso then you would be hard pressed to find a machine & grinder combo for $600
    A machine only option is a good little but hands on performer is the Nemox Fenice
    http://coffeemachine.com.au/nemox-fenice-espresso-machine-p-126.html?osCsid=5405ee16f2bbbb0cdc2f01e92ff138da
    If you like good coffee thats not espresso style you cant go past the Kyocera grinder/Aeropress combo
    http://coffeesnobs.com.au/YaBB.pl?action=usersrecentposts;username=4B5F754E1 82A0
    Note always use fresh coffee thats freshly ground for best taste & results
      thanks for those links
      I usually just drink lattes,
      so would the silvia be a good option, ive read that the milk frothing comes out really good from it
      they dont come cheap do they
        Welcome Joyo.... [smiley=thumbsup.gif]
        As KK pointed out, the Fenice is an excellent machine and so close to the performance of the Silvia that its almost indiscernible to most imbibers.... It also falls within your budget and due to their excellent build quality, return a very satisfactory sum when sold (should upgraditis bite sometime in the future). As we always say around here though, it doesnt matter how good a machine or what brew method you use, it is all for naught if you dont own a decent grinder and dont use freshly roasted, high quality coffee.
        All the best
          thank you so much for that suggestion,
          didnt know about that brand before it was mentioned here, will certainly look into it.
          i hear so much about the silvia, but will check out the nemox
          thank you
            Unfortunately no
            Good entry machines are $600 to $1000
            HX (heat exchanger) machines can cost a bundle
            Some of us have spent upwards to 4 K   on machine & grinder combos just to get a good cup of coffee    :
            But the non espresso path is the cheapest hence the Aeropress link for an alternative brew style, With a total outlay with hand grinder for under $150
              this coffee thing looks like it can get really addictive, 4K, wow.
                If you dont mind grinding by hand, then the Kyocera is a very good option and one that will last you a long long time.  PLUS .. its portable.
                The Burrs are made of an advanced, high-tech ceramic called zirconium oxide (also called zirconia). Zirconium oxide is extremely hard, wear resistant, and chemically inert. For the technically minded, zirconium oxide has a hardness of 8.2 mohs (vs. steel at 5-6 mohs and diamond at 10 mohs).
                Heres CS member  Doug81s Kyocera teamed with a Silvia
                [media]http://www.youtube.com/watch?v=eTsuDTh-Lw8[/media]
                Originally posted by 575C46540B02330 link=1240128496/82#82 date=1242096028
                Finally got around to testing this grinder with the Silvia. First 2 attempts choked it up good, but I got a shock on the 3rd try when I pulled a bloody god shot!!! One of the best shots Ive done with this machine, it funnelled beautifully and the whole shot was full of crema, settling to a nice layer afterwards. Not much in the way of fines in the cup, and tasted great! Not sure if its a fluke or not, will be trying it out again later. Not ready to give up my mazzer just yet, but its good to know that if its out of action for servicing or whatever then I can still grind for a great coffee. if it works on the Silvia, itll work on anything!  ;D
