Coffee Newbie - Sunbeam 6910
  • #16
    Re: Coffee Newbie - Sunbeam 6910
    Originally posted by 46505F455455310 link=1255613712/14#14 date=1257771304
    Hey All - Finally got the EM0480 grinder to go with the 6910
    Im able to pull good shots with decent crema but im still doing something wrong.
    The used puck is very wet and soft. What causes this. I assume its m grind being to fine???
    Anthony
    http://coffeesnobs.com.au/YaBB.pl?num=1257241858
    As stated previously..
    Plenty of posts as to the "Sweet spot" "5 cent piece" and other user guides for teh SB on teh forum... Just a bit of searching required... Always remember the search period... Day week, month - ALL.
    Could be to fine a grind, but also UNDER dosing.. 5 cent piece test... About 3 mm of the SS on the SB tamp should be showing above the lip of teh PF.... But that is on an older system... Do the 5 cent piece test to work out ya level and then go back and look at ya Grind Vs Tamp and where ya sweet spot is..
    A couple of simple steps that will see you pull top shots..
