Descaling Gaggia Classic
  • Descaling Gaggia Classic
    Probably a dumb question  - its about descaling a Gaggia Classic. I have some Cafetto - do I put 1 level scoop in the group head (with a blind filter which I have to get) and follow the instructions OR can I put the Cafetto into the water reservoir (mixed) and run the pump a number of times ,let it soak for about 20 minutes and then run pump again in short bursts ? Of course after I would run clean water thru the machine before brewing .
    The reason I asked this that a coffee machine service firm looked at machine to find out about my poor steaming problems and stated that all it needed was a good descale - to do $143 !!!
    Thanks for your help
    Re: Descaling Gaggia Classic
    Cafetto is NOT a descaler.
    DO NOT put it in the water reservoir.
    Originally posted by 1012090305131012090E070512600 link=1267252541/0#0 date=1267252541
    Yes.
      Cafetto is a company that makes backflushing detergent AND descaling solution
        Read the opening post again.
        They appear to have backflushing cafetto.
          So taking this a step further  - The product Cafetto is called Espresso Clean and should only be used to backflush ?. As this drawn  back  inside the machine does this also descale.  Probably not ?
          I was given this product from a coffee shop to help me out - Do commercial machines have to be descaled or just backflushed ?
            "Espresso Clean @home is designed to clean, descale and sanitise the brewing group, handles, filters, the milk line system and boilers of domestic and small office machines. It has a unique application where the machine has no programmed cleaning cycle (as distinct from descaling or decalcification cycle) and the brewing group cannot be removed for cleaning."
              So in short I need the Espresso @home product as the granules are not for domestic machines ?
