EM6910 After Collar Replacememt
  • EM6910 After Collar Replacememt
    Just received the SB back with a new collar fitted.
    The group handle is MUCH stiffer and doesnt want to go past the 7 oclock position without really forcing - which Im reluctant to do
    Is this normal after a repair, or could there be something not quite right - apart from the operator 8-)
    The shots seem normal.
    Id appreciate comments from those who have had this repair done.
    Re: EM6910 After Collar Replacememt
    Hey rusty, been a while since ive seen you round these parts! Is it leaking if you dont push it around past 7? if not i wouldnt worry, just enjoy the shorter journey
      I agree.. The new collar and seal will mean teh system seals better OR your OVERDOSING.
      5cent piece test ;D
      If ya can look at smoothing the step on the lugs with a dremel and and or use a little food grade grease.. I used a dash od Rice bran oil... High temp and food grade.
      If ya forcing it, then you stressing that SOFT material in teh collar.
      AM
        Mine was exactly the same. I didnt push it and before long it was at 6 oclock then 5 oclock. then 3 months later my PCB died!
          OOPS!
          I forgot to mention that the basket was empty when experiencing the tightness, so over dosing is not the cause.
            Originally posted by 6F484E49443D0 link=1268428276/4#4 date=1268453641
            OOPS!
            So.......is it leaking?
              No.. at least they fixed that
                New seals with often be tight at the start. This means that when you lock the group handle in to the group head, it often wont make it past 6 oclock. Dont force it - if it seals, thats all that matters! Over time the seal will start to perish and soften. The group handle will progressively make its way past 6oclock. When it becomes extreme, eg locking in at 5 oclock, its time for new seals.
                Perhaps the person who repaired your machine put in some spacers which may account for the the group handle locking in at 7 oclock.
                  Thank you David - that makes sense
