HELP NEMOX PROBLEM
  • newbiesnob
    Re: HELP NEMOX PROBLEM
    Originally posted by 7A253D2B202B272E2E2D2D252926480 link=1269145234/11#11 date=1269210128
    Originally posted by 575C4E5B505C4A57565B390 link=1269145234/10#10 date=1269209295
    Thanks Mal. I dont of any fellow CSers who are that handy. Fellow CSers hmmmm???
    You might have to take it to your local techie newbie...
    Not a big job, so you shouldnt be too much out of pocket...
    Thanks for your support 2mcm. Its with my local techie, I couldnt be without it. Tetleys just doesnt do it for me in the morning ;D
  • Palolo
    Sounds like coffee has been sucked back up and blocked the pipe to the group. When you turn the pump off, does any water come out of the 3 way solenoid? If no, i think it might need to be disassembled to be fixed. If yes, then you might be able to fix the blockage by sticking a pipecleaner or something through the outlet in the group to try and dislodge the blockage. At worst, you will push coffee into the boiler, so dont push to far or hard, but you should be able to flush it out anyway.
    Just trying to save you a service fee, and Im not too sure if this is even a viable fix. So maybe someone could give some input before you try it.
    Good luck!
  • newbiesnob
    Originally posted by 616A786D666A7C61606D0F0 link=1269145234/8#8 date=1269181196
    Originally posted by 78575E5C4B745857585E5C545C574D390 link=1269145234/5#5 date=1269180320
    My guess is that you have ground coffee in a solenoid or valve and it will require dissambly to manually clean..
    I think AM is right, it was a stupid sleep deprived thing to do :-/
    Yep, I think AM is probably on the money as well... And dont be so hard on yourself Newbee, we all need sleep and Ive done waaaayyy sillier things than this because of too little....
    Taking it to a reputable service professional is probably going to be the best way out for you though, especially with a very unhappy littlen demanding most of your time. If you know of any fellow CSers in your neighbourhood who may be able to help you out, that could be another option?
    Anyway mate, all the best to you and your little one....
  • newbiesnob
    Im guessing that Ill be taking it for a service & major clean asap  :-[
  • newbiesnob
    Yes, it does, sound similar. However, thats where it stops.............
  • simskade
    Is it possible that whilst under pressure the puck has pushed up into the group head causing a blockage? - does the pump sound the same as when you backflush against a blind basket?
  • A_M
    Originally posted by 6E6577626965736E6F62000 link=1269145234/4#4 date=1269178909
    Thanks Mal for getting back to me. I have refitted shower screen & tried - no luck. Ive taken off group head seal & teflon spacer & given them a good clean. The pump sounds as though its about to deliver water & then it just seizes.
    Any thoughts?
    C
  • newbiesnob
    Any thoughts?
    C
    Originally posted by 0E0517020905130E0F02600 link=1269145234/2#2 date=1269146359
    I was doing the backflush yesterday & clean forgot to put it back on. Ive had a horror few days of lack of sleep , the 2yo has had croup
    Poor little bugger.... You too Newbee....
    Have you refitted the shower-screen in the mean time and if so, can you describe in as detailed a fashion as possible, what the symptoms are? This will help us to help you get things up and running again as quickly as possible.
    I spose if youre really desperate though, you could drop your machine off to the vendor you bought it from to have it checked out, or maybe one of our Site Sponsors and explain your dilemma...
    Wish I could offer more advice Newbee but need more info.....
    All the best,
  • newbiesnob
  • Koffee_Kosmo
    Why was the shower screen off?
    Normally it takes a screwdriver to remove it from the group head?
  • newbiesnob
    started a topic HELP NEMOX PROBLEM
    HELP NEMOX PROBLEM
    I accidently pulled a shot this morning without the shower screen on (major lack of sleep) :-[ It seems, nothing is happening now, no water is pumping through. Is there anything I can do, or is it cactus?
