Steam on 6910 stopped working
  • A_M
    Re: Steam on 6910 stopped working
    Originally posted by 3A3823292F393A3823242D2F384A0 link=1273617065/4#4 date=1273641633
    Originally posted by 49666F6D7A456966696F6D656D667C080 link=1273617065/3#3 date=1273639545
    Be genital and when you softly and slowly open the steam knob
    I hope you dont mean this - it could be real nasty LOL
    Ok OK OK... Speeling police and I am tired..
    Champex and extra early morning to get daughter to exam on time and NO BLOODY lung lollies..
    Need different and more meds   ( Or a sharp knife and a windpipe)
    Originally posted by 1D193F2626233C2B244A0 link=1273617065/5#5 date=1273641773
    Dont worry, AM is an expert at being a genital! lol
    Mr W Sully...   7 Kg of Brown to go and  3 days till pick up...
    Care to make it last a bit longer   ;D
    OH the power and I am not even a mod in this section  or had a story published
    Get used to it   ;D : :-* :-* :-*
  • WSullivan
    Originally posted by 4042595355434042595E575542300 link=1273617065/4#4 date=1273641633
  • pricespringer
  • A_M
    Originally posted by 3A212037767E7C764E0 link=1273617065/2#2 date=1273630243
    Originally posted by 557A73716659757A75737179717A60140 link=1273617065/1#1 date=1273617731
    2: No steam pump working
    No pump noise, no steam....it might as well be off.
    It did get started again, but Id say there is a problem.
    Could be the Pump or the Switch...
    Be genital and when you softly and slowly open the steam knob... You should hear a very soft click...
    There is a small micro switch with a SS lever that is activated by the internal knob.
    On 3 recent EM units I have see it where teh SS lever part has come away from the switch... But if flexed / wiggled the system would work.
    A: See if ya can hear the click
    B: Give it a firm but soft wiggle etc and see what happens.
    If nothing - First guess is teh Steam pump = Warranty OR a broken switch..
  • tony8028
  • A_M
    Originally posted by 2F343522636B69635B0 link=1273617065/0#0 date=1273617065
    The steam arm on my 6910 suddenly stopped working yesterday. It eventually started working again until this morning when it was again dead before i got working around 10 mins later.  Id describe it as intermittent.
    I assume it will need to services (still under wtee) but is there anything I can do or check that might fix this? I assume like most problems with this machine, its quite common.
    Depends on what ya mean - stopped working..
    1: No steam but pump working OR
    1: Implies crap in the system - may or may not be a simple fix
    2: Could be a faulty pump or switch - Time consuming and machine needs to be pulled down.
    Dead pump is covered under warranty... Other causes MAY NOT be...
    TAT will depend on the service agent...
    Have a look through the EM69XX posts / topics... Many talk about steam and possiable fixed... But it all depends on what the REAL cause is.
  • tony8028
    started a topic Steam on 6910 stopped working
