Upgrading from EM6910 to Silvia?
  • Upgrading from EM6910 to Silvia?
    Hi All,
    I found this site while searching for answers to the reliability issues with our EM6910. It is less than 3 years old, and has had the steam pump replaced twice, the collar replaced once, and has now gone back in because its leaking water from underneath. It started this when i came back from the last steam pump replacement, but Im not expecting the repairers to accept responsibility for it.
    Im sick of it breaking down, Im sick of having to pay a fee up-front for warranty repairs (then having them come up with a reason not to refund it), and Im sick of being without coffee for up to 4 weeks when it does need repair. Ive done a fair bit of reading on CS, and it seems the general concensus is that the Silvia / Rocky combo is a good option.
    Since we purchased the M6910 in 2007, we have been very happy with the quality of coffe it makes. We use supermarket coffee - usually 250gm pre-ground bricks from Woolies, and when used with the dual floor filter basket the result is (usually) a very nice coffee - better than many weve had from cafes, but not as good as the very good ones. We only drink lattes, so are making the same thing every time. The EM6910 guage sits at about the 1 oclock mark with the dual floor filter, and if the machine was reliable wed be happy to keep using it.
    I have tried to use the single floor filter basket in the past, but havent been able to make a decent coffee - if I remember correctly it comes out with no creme and tastes like crap. I have no idea if the problem is related to the coffee we are using, the machine itself, or my technique. I suspect its a combination of all three. Im a bit worried that if I buy the Rancilio combo I may not be able to make a decent brew, and will be disappointed with the purchase. Hence this post, and a few questions:
    A lot of people bag the supermarket coffee, but why? Is the grind wrong, or is it just the freshness of it that makes it sub-standard? Would I be able to make a half-decent esspresso with the Silvia using supermarket coffee, or is there a huge difference using fresh beans & grinding it myself as needed? Would anyone suggst we just buy a Silvia, and continue to use supermarket coffee?
    Following on from this, how fresh should the beans be for optimum coffee? Do people realy buy fresh beans every few days? How quickly does the flavour start to degrade, and how much does it change? We are not (at this stage) looking for perfection, just a nice tasting coffee. Having said that we have paid for many coffees that we just didnt like at all, so we are a bit fussy.
    Given my inability to make a decent esspresso using the single floor basket on the EM6910, how much of a learning curve will I have to make a decent shot on the Silvia? What will I have to do differently? Will I need a barista degree to drive it?
    What is my EM6910 worth as a used machine - assuming its fixed this time?
    Any help is appreciated.
    Geoff
    Re: Upgrading from EM6910 to Silvia?
    Hi,
    The freshness of the coffee makes a huge difference, At work we are supplied beans that usually are good for a day after that it is back to the dual floor.
    At home I have gone through the quest for fresh beans and now roast them myself in the breadmaker.
    As an experiment get some supermarket beans and some freshly roasted, and make a plunger/french press. you should see a bug difference, then if you can get some just roasted beans and try again. These will be gassy and not at their peak, but the plunger coffee will look like it has been carbonated. (Actually plunger is how I prefer freshly roasted beans)
    soooo.... answering you question, if you are happy using the dual floor with supermarket coffee, then you may be better off with a cheaper machine. This method does produce a more consistent coffee with less skill.
    Going for a grinder and fresh beans will give you, what I think is better coffee, but that is my opinion!
      Gday G-Dog.
      As a Silvia owner, let me say that getting a decent shot out of it isnt that hard. There is only one little thing that makes Ms. Silvia a bit different (IMHO) and that is the depth of the shower screen. Which makes her a tiny bit sensitive to the load you put in the PF.
      As said already though - youll get a stunning increase in coffee quality by going for beans + grinder. Youll more than double that by going for fresh beans...
      Apropos the freshness, there is an oft quoted rule of 3s - ground coffee lasts for 3 minutes (I reckon it is more like 30 seconds, you can tell!); roasted beans last for 3 weeks. The rest of it is greens last for 3 years, but I think they go longer if you store them right.
      My eldest daughter has a 6910. She thought shed been bought a dud - her coffee was horrible in comparison to the coffee she got at home. So I took the Rocky and some beans around. Instant gratification! I now roast her some each fortnight. She has also bought a grinder. The grinder alone made a big difference from the store ground.
      I think the 100% truthful answer is replacing the 6910 with a Silvia wont change the taste of the coffee. Buying a good grinder and fresh beans WILL. As in make you wonder what youve been doing the last couple of years
      If you do buy a Silvia, youll need to buy some baskets (or get them thrown in with the purchase). Synesso or La Marzocco baskets are the go. And always use the double basket - the singles are hard to get used to initially.
      If you fill in the where you live bit of your profile, there might be a local snob who owns a Silvia whod be happy to show you and let you try! If youre in Adelaide, feel free to PM me.
      /Kevin
        Thanks for the replies.
        Kevin, I assume from your answer that the standard basket that comes with the silvia is not as good as the aftermarket ones. Is the difference in the quality of the coffee or in how hard it is to use?
        I assume that all the mentioned baskets are single floor - is the Sunbeam the only machine that uses dual floor baskets?
        We only ever use the double basket - if we are only making one coffee we use a larger glass and a double shot.
          Ive used a 6910 over the last 4 years and this is typical.
          Personally I dont think it will last much longer.
          I find this incredible!
          Only 4 weeks? Lucky.
          Thats because you havent tried better . . . yet!
          Thats because its designed for use with freshly ground coffee, and thats not what youre using.
          Lack of freshness.
          NO!
          Its all a matter of personal taste.
          I roast my own but occasionally buy from a few trusted sources.
          I prefer most of the coffees I like around the 7 day mark but they are drinkable a few days before and some time after but never last much longer as I dont buy or roast more than 500g at a time.
          The flavour will change; how much depends on the particular coffee.
          Sometimes that change is another enjoyable part of the journey as the changes are not necessarily bad, just different.
          No. A lot of the cheaper "appliances" do.
          Originally posted by 6C6D6A270 link=1275790026/2#2 date=1275795841
          I think the 100% truthful answer is replacing the 6910 with a Silvia wont change the taste of the coffee.Buying a good grinder and fresh beans WILL.As in make you wonder what youve been doing the last couple of years
          Seconded. The cheap way to convince yourself theres a lot better coffee to be had is to buy a decent grinder and fresh beans.
          The 6910, when working, with fresh beans, is capable of making an excellent coffee.
          P.S. Welcome to Coffee Snobs.
            As per TG..
            There are people who love the Silvia..  Others hate the Sunbeam..
            Fit for purpose....  Never had a major problem with my EM6910 X 2 (home and work) - Minor issues were all user started.
            1: From what has been posted and I have seen..
            Service agents have a lot to answer for..  Board jockies and no true understanding of the electronics and or mechanical issue at hand..
            2:  Have recently seen a couple of OLD EM6900 with org collars... Thin and warn.. But OK..  NO other faults.. Never really cleaned correctly and only one seal change..
            3:  Steam issues ...  Cleaned / De scaled and all working.. One had lots of coffee fines in all the plumbing... BLIND filter...   User and Water..
            I would not call going from an EM6910 to a Silvia as an upgrade..
            Side step at level at best...  $200 for a boiler and dont get carried away with steam and or 4 or more shots in a row.... And temp surfing etc...
            Fit for purpose...   Just be warned .. The EM6910 has spoilt you.. The next step is bigger than you think.
              Well, I got my Silvia from Chris (2mcm). He supplied bigger baskets. The Rancilio ones are incredibly small. The single would barely hold 7g. So the original equipment, while technically correct is insanely unforgiving (IMHO). A pair of Synesso baskets will set you back a whole $20 (again, unless the vendor chucks them in as part of the deal).
              My "double" basket is actually a triple, I think. I dose it with 17 - 18g of coffee and it makes 2 KJM strength espressos.
              I really think itd be worth your while ordering some brown beans from Andy or some other local trustworthy roastery and getting yourself a grinder. You could even cheap out and get a hand grinder (Hario or Kyocera) while you get it sorted. The 6910 does make a fine cup - as I said, one of my daughters has one. You might discover a new love of coffee! And then decide to spend on a better machine!
              While everyone needs to discover this for themselves, the order of importance of things is: Fresh Coffee, Grinder, Person-who-knows-their-stuff and lastly the machine. I cant believe the difference grinders make!
              /Kevin
                Thanks for all the info - great site.
                I think in my mind Im ready to change. Ill be happy to be able to make coffe as nice as we have now, without the reliablity hassles, so I think the Silvia is the go. With the grinder its about the max Im prepared to spend at the moment. Im just waiting to hear back from the repairer, but Im not going to spend much more on the 6910.
                A couple of qs about the silvia, though - can it steam & make esspresso at the same time (I think the answer is no), and does it have a one button auto mode for esspresso like the 6910 (same answer I think). If not I assume you have to time the shot - how hard is this to get right?
                Cheers again,
                Geoff
                  Morning Geoff,
                  I cant compare the Silvia to a Sunbeam never having owned the latter, however I can tell you that the Silvia is an easy to use well made machine that holds its resale value very well.
                  The Silvia cant steam and make espresso at the same time.
                  It doesnt have a one button auto mode.
                  Yep you need to time the shot, how difficult? nothing to it, just use your wrist watch or a small clock with a sweep second hand.
                  Despite posts to the contrary the Silvia is not a difficult machine to master, bit of a learning curve but a week will see you pulling pretty good shots.
                  As has been said before, if you dont have a fresh beans and a decent grinder you wont get decent results from any machine, supermarket and the term good coffee should never be used in the same sentence, it just dont happen.
                  Perhaps buying a decent grinder would be a smart next move, I doubt a Silvia and coffee from the local Woolies will give you any improvement over the Sunbeam.
                  Good luck.
                    Good luck.
                    All 100% what I would say too. The timing though - you just count to 20 (slowly). Timing 20seconds (or 22 or 25 or whatever you think it should be) isnt hard.
                    But the fresh beans + grinder is super, super important. Stale beans will require a dust-like grind to get a 20 second (or whatever :) pour. And will taste like something brown which isnt coffee....
                    If I were advising someone on what to do, getting the fresh roast and a grinder would be #1. Then you can see what it should taste like. The 6910 will give you a perfectly good shot - I reckon a Silvia would be (marginally) better, but basically as good as youll get without laying down insane amounts of cash (KJM reveals him self as a cheapie here. No $3k HX machine! No $3k to spare!!....)
                    The other thing to do would be to trundle along to a proper coffee place. The site sponsors are a good place to start. You can try a coffee there or even get a demo of a domestic machine to see how different it is from what youre used to.
                    /Kevin
                      Having helped a friend or two out with their Sunbeams, I find that they are as stated fit for purpose and I can also attest to the china quality build and quality control. Despite propper care and use, both guys have had several part failures and experienced the boiled rice warranty.
                      I think the fit purpose largely being someone who only does a couple of shots in a milk drink a day (so as not to wear it out), moslty finds themselves pressed for time for making said milk drinks, isnt into espresso in a big way and has a small budget.
                      Despite some claims to the contrary to get the most out of one of these I found a warm up time in the same ball park as most other machines is actually required with only the steaming on demmand being the real time saver. (about 20 min or so)
                      With fiddling they produce ok shots. Only with forgiving beans can they produce something at best good not great. For this money you dont get great so thats fine.
                      Ive done a few comparisons with my back up Ikon to help a friend with some extraction issues he was trying to sort. We used it as its easy to pop in the car and is a peer in terms of limited shot potential for a benchmark. On back to back shots with as much fiddling as we could we found the Ikon cracking better flavoured doubles on more than one blend of fresh stuff. There was clearly some flavour missing and less clarity even after lots of shots worth of changes to the Sunbeam. The efforts definately werent wasted all the same with the 6910 doing miles better at the end. But, it was funny to find the Ikon budget special making a little better coffee. Again, not that either was great.
                      If Sunbeam/Breville could just ping something like the Ikon boiler in along with the steam thermo block you could have a real cracking budget machine.
                      I havent had a go at a Silvia but, it wouldnt suprise me if it made better espresso shots at all. It would certainly work better with a greater variety of beans than the 6910 if the Ikon is anything to go by.
                      Hope that helps add something.
                        Interesting... And open to debate any time..
                        As often said here... PEBFAG..
                        Reliability / build quality / Cost etc etc all have some interesting pro and cons.....
                        Shot quality comes from the user.....
                        Please explain this train of thought as to the beans being the critical factor in the manner and context your referring to.
                        I would like to know more of the wisdom and of teh beans your indicating as being special?
                          Originally posted by 69464F4D5A654946494F4D454D465C280 link=1275790026/11#11 date=1275904784
                          I would like to know more of the wisdom and of the beans your indicating as being special?
                          I dont think Ive got any wisdom to pass on with the beans bit, maybe I do? I kind of assume people find the same thing out over time using different beans.
                          Its probably the absence of special in the beans/blends. For some reason I find some beans are just more forgiving. In any combo of prep, pour and taste. I could put this down to different chemicals and bean structure that are responsible for the differences but, I wouldnt know where to point on that one. As an example I find that brazil pulped natural on bean bay to be relatively forgiving (also a bit boring by itself) despite machine. Drink it on a friends 6910, Ikon, ECM it all tastes pretty much the same.
                          When you talk about the cheapo devices they do it tough keeping stabillity in the physics happening where it should by comparison to something more commercial. The Sunbeam thermoblock is fighting against small thermal inertia and for what it is it does bloody well. From what I remember it was a tad cold blooded by comparison to the little Ikon in the shots we measured (we were trying to get it bang on). It took a bit longer to get where it needed in the temp during the pour every time. My guess is this is why acidity and intensity was down a little. The basket designs are totally different too and no doubt the pressure of extraction variables are there as well.
                          Youve got no worries getting shot qualtiy from the Sunbeam, relative to its limitations not mine or my friends. It gives as best it can and my friends are happy with that. Better than 90% of the cafes around at home is better than a poke in the eye with a sharp stick.
                          I probably made that as clear as mud ;D
                            Ya did a good job.. but.... Any number of assumptions and possible points that many would question...
                            Would suggest other than the Beans and the Grinder - you and ya friends are the the limitation..
                            Do not know of many systems, that can cost in excess of thousands; where teh user is NOT the limitation.... Other than super Autos... But then teh use caused teh problem by buying it
                            EM6910 Vs Silvia... Fit for purpose and cost..
                            To teh OP - Have a read... A bit dated but on teh money.. No mention of issues as to what beans the machines can not manage.
                            http://www.coffeetamper.com.au/**/reviews/sunbeam-silvia/
                              As someone who has done the opposite of what you are planning, and "side-graded" from Silvia to 6910, this is quite a tricky choice.
                              Having used both, apart from durability, I would choose the 6910 every time. It is very easy to use and I find the feedback you get from it makes fine tuning your grind/dose/tamp intuitive.
                              Others may have not had the problems I had with Ms Silvia, but in almost 12 months I was unable to consistently get grind/dose/tamp/TEMP all to align for decent espresso, which was very dis-heartening to be honest.
                              I got all of this sorted on the 6910 in under two weeks, and this has been consistent now for several months.
                              If you go for the Sylvia, make sure you do a search on "temperature surfing" and "PID", as you will eventually need to address temperature if you want properly good coffee. Maybe not a big deal in itself, but when combined with dose/grind you can easily wind up chasing your tail. Suggest you buy from a sponsor and get training included in the purchase.
                              Btw, Silvia has a small water tank (2L) and tiny drip tray (~600ml), so you will be for ever tending to both ;-)
                              Good luck with your decision!
