Broken part from Silvia?
  • Broken part from Silvia?
    Hi All,
    Just looked in my drip tray of my Silvia and there is a piece broken off just lying there...
    I have attached the photo.
    What is this piece? is it apart of the machine?
    How did it brake.... and do I need to replace?
    So puzzled by this...
    Thanks for your help
    Re: Broken part from Silvia?
    Only a possibility & thinking on simple things first
    Could be a shaft that goes inside the foot
    Lift the machine a little bit and see if a foot is loose
      hmmm feet seem to be fine and machine is working as per normal.
      Thanks KK for your response...
        Well the next thing is
        Check the panel security & if all is OK then you will need to look inside
        That brass collar normally fits in a hole and when the screw is tightened it expands a little to secure the object or objects
        Such as a panel to a frame but it could be something else
