Newbie to Gaggia Classic - brewing problems
  • Newbie to Gaggia Classic - brewing problems
    Hi, I have just brought a gaggia Classic - being my very first machine. Obviously on a huge learning curve, but am having probs already - every time I brew, the coffee spurts out of the delivery spout (and up the walls!). Thinking I may have too much, or too little coffee in, I have tried both with results still the same. Same result with tampering light or firmer. Any suggestions from much wiser and exprienced members would be greatly appreciated? I am booking into a course asap Many thanks, Kim
    Re: Newbie to Gaggia Classic - brewing problems
    Will try to help, but Im not certain from your description exactly what its happening. A course may not help with this unless they can show you how to use your own machine.
    What beans and grinder are you using? Or are you using preground?
    When you say it spurts out the delivery spout, is it around the edge of the portafilter, our the holes in the bottom where it is supposed to?
    If you are using a pressurised basket, or a single basket, change to the normal double basket (straight sides, you should be able to see light through the holes in the bottom). Make sure the machine has had at least 5 min warm up, 10 is better.
    Try pulling a shot with no coffee at all, just an empty double basket. It should trickle out in a steady stream, if not there is a problem.
    One suggestion is to buy some preground beans, not ideal, but useful for initial testing and learning. I have managed to get some crema with Grinders pre ground coffee.
    I you have accurate digital kitchen scales, place the (pre warmed) filter handle with basket on the scales and zero it. weigh out 16grams coffee into the basket - a yoghurt pot with the base cut off helps to avoid mess when filling it. Tamp it down well and latch FIRMLY into place on the machine. Now remove it and look at the top of the tamped coffee, if the surface has been disturbed, then you had slightly too much coffee, reduce amount and try again.
    Assuming all is well with quantity (dose), relatch the filter handle and press the pump switch. It should, ideally, extract about 60 grams of coffee into your cup in about 30 seconds. First attempts will probably be much quicker, but measuring time and weight will give some ideas what is happening.
    Good luck.
      Thanks for your reply. Will try the scales test and see. Water flows well and evenly from the shower head, as well as throught the portafilter and basket (seperate and together) when free of coffee. I feel it may be my tampering technique, and/or the beans. I am using freshly roasted and ground beans, and had them ground fine at the roasters. Could it be the pressurised basket? I am going to get a normal basket to see if this is the problem too.
      Just tried 4 times and sooo frsutrated! But not giving up
        For good espresso extraction an un-pressurized basket must be used in conjunction with:
        - freshly roasted beans from a high quality roaster
        - consistent tamp
        - consistent bean weight
        - a variable grind that adjusts depending on many factors from a good quality espresso grinder.
        - 9 bar of pressure for coffee oil extraction at approximately 92 degrees c.
        Your grinder and basket are issue. Lots of posts on these, use the search and dont forget to set the time frame for more than 1 week.
        Good luck
          Im surprised you only got the pressurised basket with the machine. That probably accounts for a lot of the issues you are having.
          Whereabouts are you located? As the gaggia uses standard size baskets, you should be able to pick one up locally if you are in a major city.
            Did your machine come with a little black nozzle? If youre using a pressurised basket, you need to have that black nozzle inserted into your portafilter to "defuse" the coffee, otherwise youll get coffee sprayed everywhere from the pressure the basket is making.
              100% correct put the little black nozzle in the hole in the portafilter and problem solved
                Thanks everyone for your replies. Thats it! I didnt get the little black nozzle. Going through the manuals I realised that these were not in the box. No wonder - I was beginning to doubt the machine (and just quietly, my abilites
                Thanks once again, Kim
                  bump ...
                  Ive been having exactly the same problems and the small plastic  nozzle fixed it, however the manual states that this part is optional! ??????????
                  and when I do this as suggested above Try pulling a shot with no coffee at all, just an empty double basket. It should trickle out in a steady stream, if not there is a problem.  I still have water spurting out everywhere???
                  My own bloody fault really, I should have done more research but I have to say that Im disappointed with this machine! ...
                    Update ...
                    Pulled off the shower disc and holder, the screws were not as tight as I would have expected and the holder doesnt look new as I imagine a piece of cast metal should look when brand new ??? :-/
                    At least now I dont have water spewing everywhere when I pull a shot without coffee in the porta filter and with that little optional plastic part fitted  I can finally get a half decent coffee without covering the kitchen walls in brown stains ...  ;D
                      WHen I said "It should trickle out in a steady stream", I should have used the word "pour" rather than "trickle".
                      That was based on the assumption that you had  an unpressurised basket.
                      I didnt realise that in recent times gaggia had started supplying pressurised crap.
                      Ditch the basket and buy a real one. I just checked and dibartoli sell standard doubles  for 8.50 or 21g ones for 12.50.  whoever your local suppliers are wil have them for a similar price.
                      Youd be mad to keep trying to get good coffee out of the pressurised baskets, IMHO.
                      Edit: It seems that the portafilter may be unpressurised and the nozzle is what makes it pressurised . I will need to check into this, dont want to give people misleading advice. I also dont understand why coffee would spray everywhere unless grind and tamp were way off.
                        Well Im almost at the point of selling this machine thats how frustrated I am ...
                        I took the optional plastic crema part out of the basket as advised by an expert and followed the process he suggested including adding more coffee,but I couldnt even get the porta filter to fit into the machine!
                        So I removed some of the coffee, tamped very carefully and as usual during the pour a fair bit of the coffee ended up splattered on the walls ...
                        So, it seems to me that the optional plastic crema part isnt optional at all!
                        Help!!!!!    :-[
                          Hi, I have found this also if following instructions on level of coffee then tampering - basket wont fit into portafilter! So, less coffee definitely needed. Brought the unpressurised baskets (and received the crema part from the manufacturer after complaining) and I have the problem now with a single basket sticking to the ring on the shower head - the double basket doesnt so its double shots for the time being! Something to do with pressure there as well. Perservering still, but alittle over it
                            So your saying that the baskets supplied with your machine were indeed pressurised, and you bought unpressurised ones from Gaggia?
                            Anyone have pics of the differences between the two, or a link to help me work out what style mine are?
                              http://coffeesnobs.com.au/YaBB.pl?num=1295941810;start=8;action=threadpagete xt;reversetopic=0
                              Seems like it is confirmed about the baskets being pressurised, for some at least ...
