Newbie to Gaggia Classic - brewing problems
  • #16
    Re: Newbie to Gaggia Classic - brewing problems
    Pic of a couple of filter baskets. One from top, one from bottom with led flashlight showing the holes.
    Oh and always use the double basket when learning. I still have not mastered the single.
    • #17
      Thanks for putting up the pics, its clear now that the new machines are supplied with pressurised baskets, though I only had two in my box, others report receiving four, two of each kind.
      The question remains for me at least, why have Gaggia gone down this path when from most accounts here, this is not the best method ??? ...
      I can finally get a decent brew {and no mess}with the plastic crema installed at least thats something I guess.
      Now to find a local supplier who has suitable unpressurised baskets ...
      • #18
        Update ...
        Finally worked out that my biggest problem was the grind not being fine enough!
        Bought the unpressurised basket yesterday, and using the coffee supplied from Di Bartoli {free sample} I can now get a decent brew at the correct flow rate using either the pressurized or unpressurized basket!
        Also got my first completely dry puk that just fell out of the porta filter with a light tap
        Now I just need to work out how to get enough steam to heat the milk properly after fitting the Sylvia steam wand ...
        • #19
          Another Update ...
          Got my Kyocera hand grinder today and it immediately confirmed that I did need a much finer grind, in fact I thought I had set it too far as it took a few seconds before a really nice looking crema slowly dribbled out then filled my glass.
          Im slowly getting the hang of making a reasonable froth with the Sylvia steam wand, and my friends are happy enough with the cappuccinos Ive made for them.
          Even the other half whom Ive never ever seen drink coffee before is enjoying a drop these days.
          Btw, would it be a disaster if I re grind a purchase I made earlier which is just a little to coarse for my gaggia?
          Now the hunt is on to find some beans with a flavour that I truly enjoy ...
          • #20
            Thats great to hear that hand grinder does fine!!
            About the same time today I did my first proper attempt after cleaning, descaling.
            Got Di Bella Modena blend yesterday, tried setting no.5 on my EM0450 grinder, it choked the machine.
            Setting no.13-14, timed at 30sec, coffee came out properly, firstly trickles and then slowly a steady stream on only one side of the sprout . I dont have a measuring cup but I guess it is getting there. Theres crema, not too thick, maybe just nice.
            Puck came out a little soggy, but letting it rest a while it dries a little and it pop out properly making that Oreo looking cake. ( no channeling looking or crack whatsoever, so I guess its alright? )
            Just tasting the espresso itself, it tasted a little sour, and them comes the total fail attempt at milk frothing. Just using the top attachment of the plastic nozzle, using a incasa 600ml milk jug, I only managed to heat the milk. But this is my first ever attempt to frothing so still gotta take a while.
            The coffee with the milk tasted better than by itself. The texture is thick and oily, some distinc different from stovetop + milk.
            Now I need a proper tamper ( was using the plastic crap tamper ) and better milk froth technique !!!!!!!!!!
            PS: Crap, almost forgot I got exams coming in a week!! Used most of my time reading up coffee material than my notes @@@@@ )
            • #21
              Originally posted by 6B41465C497763475841280 link=1298427805/18#18 date=1306733047
              Probably a good way to totally clog up any grinder, Id suggest just chucking the stuff out or keeping it for seasoning.
              • #22
                I dont think regrinding is going to work, even if it doesnt clog the grinder, the particle size will probably be uneven. Feel free to try it as you can always clean the grinder if it clogs. If results arent what you want, you could use the rest up for cold processed coffee - plenty of threads around on how to do it, but simplest is to chuck the coffee in a container with 4 times as much water, wait 8-12 hours then strain it to remove most of the coffee and pass through a filter to get rid of the rest. Dilute to taste and keep remainder in fridge
                • #23
                  OK regrinding isnt the best option then, especially with a hand grinder.
                  I tried it out today with the pressurised basket and the little plastic accessory and whilst it flows far too quickly it was good enough with milk as a latte so Ill just drink it ...
                  • #24
                    I can;t fill my classic basket to the top either... bit of a hassle as its hard to get the exact same amount of coffee in each time, need to measure it. Have had my classic for a month, loving it and time for a new grinder as mine is not fine enough, only get a 10 sec espresso and not good crema
