Advice please.
  • Advice please.
    I have been reading and reading and a lot more reading and can not decide on which avenue to go. I have decided on the breville smart grinder however cant decide on a machine. I live in Maitland and dont really know anywhere nearby to try any machines. My partner and I want an espresso machine that is less than $800, can make two lattes reasonably quickly. The silvia seems to have a great reputation however I am undecided with the boiler size and risk of cooking it. Is this to be expected with virtually any machine under this price?
    Appreciate any help at all as I am new to the world of espresso.
    Aaron
    Re: Advice please.
    Hi Aaron
    Have a look at the Lelit, they might fit the bill, they seem to do better than the Silvias.
    ETA: In line with CJs comments I should add that I havent used either and Im just going on the research Ive done looking at machines    I would drive to Sydney find someone that has both machines and ask to try both and then see which one you like better.  Jetblack have both and they are the closest to drive to from here
      Re: Advice please.
      Hi Aaron.  I think the Breville grind is a good choice.
      With regards to machines I believe there are only 3 you should consider:
      Lelit PL041
      Rancilio Silvia
      GEE (just over budget)
      The Lelit & Silvia are pretty similar machines with respect to design and use and I have owned both.  Personally Id go for the Silvia.  Small price difference, better build, commercial group and better resale.
      The GEE is a completely different beast. More plastic compared to the Silvia but larger boiler and separate thermoblock for steam.  Also has PID temperature control and adjustable preinfusion.  It really doesnt have a peer.
      So for me its either the Silvia or the GEE.  The GEE is a more advanced machine but still relatively new so there are uncertanties regarding longevity.  I have looked inside the guts of one and it certainly looks well put together. The Silvia has a good quality stainless steel exterior whilst the GEE has a more applicance-type appearance with a combination of plastic and coated metal.
      As with all single boiler/dual purpose machines the Silvia is a bit painful & slow when making more than 2 milk coffees at a time.  I have not used the GEE but presume with its separate steam thermoblock it should be much better for entertaining.
      As long as you use the Silvia correctly & refill the boiler each time after steaming milk you should not run a risk of cooking the element.
        Re: Advice please.
        I went from a thermoblock Breville to the Silvia and they are worlds apart.
        Just a different process but once you get a routine you can do two milk based coffees pretty quick.
        The refilling of the boiler is just a part of the process and you can not harm it if you do it right.
        I was a little paranoid about cooking mine before I got it but it is not that challenging to keep it full.
          Re: Advice please.
          Hmm, all things to consider.
          Thanks for the advice, I think I will have to get in contact with the likes of jet black espresso and travel down that way in the coming weeks.
          Cheers again for the help guys,
          Aaron
