Technique Using Pimped Rancilio Silvia - Seeking constructive criticism
  • Technique Using Pimped Rancilio Silvia - Seeking constructive criticism
    Hi there,
    In the interests of ongoing, improvement and learning, constructive feedback from those with more experience and knowledge is welcomed!
    [media]http://www.youtube.com/watch?v=NJRSeu-z1DU[/media]
    Many thanks (I think) in advance
    BTW, the coffee is Brazil Bourbon.
    Re: Technique Using Pimped Rancilio Silvia - Seeking constructive criticism
    I would suggest that your espresso is overextracted as it looks like you have extracted close to 100mls rather than 60mls. Try pouring 60mls into a shotglass, then tip the shotglass into a cappucino cup to get a guide of where to stop the pour.
    To me, the pour looks a tad blonde - you should try to stop it earlier.
    We all have lots to learn, so happy learning, and good luck!
      The shot was a bit of a gusher, grind finer. Should take 5 - 8 secs for the espresso to come out after you activate brew switch.
      A Silvia with PID would go much better with a better grinder.
        Will do the 60ml measure and set the grinder on the finest possible and give it a go.
        Thanks for the tips!
