Silvia - Boiler insulation Pros & Cons
  • #16
    Re: Silvia - Boiler insulation Pros & Cons
    Thankyou all for the feedback.
    I,m really encouraged to go ahead with the silicon foam and called into Clark Rubber Balcatta thinking theyre sure to have it. They had offcuts but it was working out much cheaper to buy the already cut kit plus postage from the US. Im thinking It may be an opportunity for one of the CS sponsors to offer this foam as sheets or kits for the Australian market.
    Those of you that have bought from Pidsilvia.com did you purchase the pre-cut kit, kit with template or sheet?
    I feel like drinking those two InTheCup coffees now.
    • #17
      I bought the pre-cut.
      I actually had to cut a piece down that inserts over the group head. As in its original size there was too much overhand and I couldnt get the plastic group head cover to fit back neatly.
      But in cutting it down its fiddly stuff as it warps when you try to cut it. Using something like a very sharp knife is better than say scissors.
      • #18
        Note in my previous post. I had to remove the wrapping from the top half of the steam pipe due to clearance issues.
        But I dont mind having it partly exposed as I still have a cup warmer 8-)
        I have dealt with PIDSILVIA before for a flat shower screen and they deliver promptly. But that said I have watched his YouTube video which serves as the instructions and note; the way he wraps the steam pipe you would never be able close it up again without trying to warp the cup warmer as the pipe sits mms below the tray.
        Words of caution the guy from PIDSILVIA fully removed the boiler from the machine... which in my opinion is not an option taken lightly. I was able to do it without doing a full removal but when attempting this it helps to have a second pair of hands as removing the front panel of the Silvia to access above the group is tricky without someone to hold it while you manoeuvre everything into place.
        • #19
          Originally posted by 3B302A312B34363F580 link=1309610800/13#13 date=1310190408
          Edit. I had to remove the insulation from the top section of the steam pipe as clearance was an issue. So now I have only insulated the steam pipes lower half.
          I had the same problem, what I did was put some rubber washers under the 4 screws to lift the top panel up a bit. This ensured that it had the clearance and also some ventilation, worked a treat.
          I bought pre-cut but having installed it and cut it now you could save money and just go with a template as the material is very easy to cut.
          • #20
            I did write of to ask about the uncut 12"x12"x1/4" with template kit did it include 1/8" thick foam for the steam pipe & grouphead. The answer was no but there was enough material to splice it. I guess with a steady hand and sharp knife this wouldnt be too difficult and the cost is $36 instead of $50 plus postage. Good tip about lifting the top panel up from MrDerrickC.
            • #21
              Interesting that it doesnt include the steam and grouphead..... doesnt make sense. The photo from their site shows the non cut covering the steam pipe and I would assume grouphead too.
              The material is very easy to cut with sharp scissors, I cut some of the left over pieces that they included to cover some parts of the steam valve.
              • #22
                Did you try "Butt Wrapping" the Steam Pipe rather than the "Half Lap" method you used? Im sure this would still provide adequate insulation but maybe reduce the need for extra clearance.... 8-)
                • #23
                  Hi,
                  1. when wrapping the steam pipe, you should not have the insulation overlapping like in the picture at the previous post, you should start the overlap only on the way down.   you can only have 1/8" of material on top.  you should have the clearance if you dont overlap at the top.
                  2. this material is very soft, in most cases you can fit it with no cutting. (push or stuff it in for better fit)
                  3. i will add some notes in the instruction regarding this.
                  i hope this helps.   i can better reply to emails.
                  Thank You !
